Web Interface Tutorials
Web Interface Overview
This chapter shows you how to use the Zyxel Device’s various features.
Device Settings - Rename your Zyxel Device, change the admin password, change the management IP address, and create another admin or user account.
Wired Network Setup - Set up a wired network connection using DSL, GPON, or Ethernet.
Wi-Fi Network Setup - Change the Wi-Fi name, password, and security mode; connect to the Wi-Fi network using the WPS; set up a guest Wi-Fi network with different Wi-Fi bands; and configure the channel and bandwidth for each Wi-Fi band.
Cellular Network Setup - Set up a cellular network connection.
USB Applications - Set up file sharing, play files through Windows Media Player with a USB device, and set up a print server.
Network Security - Configure a firewall rule and scheduler rule, set up parental control rule, set up home security, and configure a MAC Filter rule.
Secure Server Setup - Set up a DMZ server.
Internet Calls - Add a SIP service provider or a SIP account, to make phone calls over the Internet.
Device Maintenance - Upgrade the firmware, back up the firmware, restore the Zyxel Device configuration, and reset the Zyxel Device to factory defaults.
Remote Access from WAN - Configure remote access to your Zyxel Device and configure the trust domain.
System Log - View the system log of the Zyxel Device, send the log file through E-mail, and monitor power usage.
Device Settings
This section shows you how to:
You can rename your device, and change the admin password.
Rename Your Zyxel Device
An FQDN (Fully Qualified Domain Name) is used to identify a specific host on the Internet, consisting of a host name and a domain name.
Proper naming of the host name and domain name makes the Zyxel Device and the network easier to identify, manage, and troubleshoot. The host name is the name of your Zyxel Device, while the domain name is the name of the entire network your Zyxel Device belongs to. If your Zyxel Device's host name is room1, and it belongs to the domain you name with home.com, then your Zyxel Device's FQDN would be room1.home.com.
To change the host name and the domain name, please follow the steps below:
1 Go to the Maintenance > System screen. Enter a new host name in the Host Name field and a domain name in the Domain Name field (special characters and spaces are not allowed). Click Apply.
2 Go to the Connection Status > System Info. You can see the new host name has been applied successfully.
Change the Admin Password
Change the Web Configurator login password regularly to secure access to your Zyxel Device. To change the admin password, follow the steps below:
1 Go to the Maintenance > User Account screen. Click the Edit icon.
2 The User Account Edit screen appears. Enter your old and new passwords in the corresponding field. Click OK.
*The new password must be at least 8 characters, must contain at least one uppercase letter, one lowercase letter, one number, and one special character. For some models, the password must contain at least one English character and one number. Please see the password requirement displayed on the screen.
Change the Management IP Address
Duplicated IP addresses in the network environment may cause failure to connect to the Zyxel Device. To change the management IP address of your Zyxel Device, please follow the steps below:
1 Change your computer’s IP address to the same subnet as the Zyxel Device. For example, if the default static IP address of the Zyxel Device is 192.168.1.1, set your computer IP address between 192.168.1.2 and 192.168.1.254.
2 Log into the Zyxel Device using the default IP address “192.168.1.1” “192.168.15.1”. Go to Network Setting > Home Networking. Enter your preferred IPv4 address in the IP Address field. For example, “192.168.1.15”. Click Apply and the Zyxel Device will disconnect from your computer due to the IP address change.
3 Enter the new IP address “192.168.1.15” in the address bar to check if you can access the Zyxel Device’s Web Configurator.
4 After logging in, click the menu icon () and go to Connection Status. In the LAN section, the IP Address should now be “192.168.1.15”.
Create Another Admin or User Account
To let multiple users access the Web Configurator, you can create more than one Administrator or User account. A total of eight users can log in to the Zyxel Device at the same time.
The total number of accounts you can create for each group type:
Administrator Account
4
User Account
4
The steps below shows how to create Administrator and User accounts:
1 Log into the Web Configurator. Go to Maintenance > User Account. Click the icon on the right to Add New Account.
2 The User Account Add screen appears. Enter the information for the new account. In the Group drop-down list, select Administrator for the account. Click OK.
Administrator and User accounts have different privileges. For more details, please refer to User Account.
The example below uses the following parameters for the new Administrator account.
Username
Julie
Password
Zyxel1234@@!!
Retry Times
3 Times
Idle Timeout
60 Minutes
Lock Period
5 Minutes
Remote Privilege
LAN/WAN
3 In the Maintenance > User Account screen, an Administrator account named Julie has been created. To add a User account, click the icon on the right to Add New Account.
The grayed-out box indicates the logged-in account. The highlighted box indicates that the status of the other account can be modified. In the below example, the logged-in admin account can block Julie’s account by deselecting Julie’s Active checkbox.
4 The User Account Add screen appears. Enter the information for the new account. In the Group drop-down list, select User for the account. Click OK.
The example below uses the following parameters for the new User account.
Username
Stephenie
Password
Zyxel123!
Retry Times
3 Times
Idle Timeout
30 Minutes
Lock Period
5 Minutes
Remote Privilege
LAN/WAN
5 In the Maintenance > User Account screen, a User account named Stephenie has been created. Click Apply to save the newly created accounts.
In the below example, the logged-in admin account can block Julie’s account by deselecting Julie and Stephenie’s Active checkbox .
Wired Network Setup
You can set up a PON, DSL or Ethernet Internet connection with the Broadband screens. The screens vary by the connection mode, encapsulation type and IP mode (IPv6 or IPv4) you select.
You can set up a DSL Internet connection with the Broadband screens. The screens vary by the connection mode, encapsulation type and IP mode (IPv6 or IPv4) you select.
Set the Zyxel Device to Routing mode or Bridge mode on this connection as follows:
Use Routing mode if you want the Zyxel Device to use routing mode functions such as NAT, Firewall, or DHCP Server. You will need to reconfigure your network if you have an existing router.
Use Bridge mode to pass the ISP-assigned IP address(es) to your devices connected to the LAN port. All traffic from the Internet passes through the Zyxel Device directly to devices connected to the LAN port. Use this mode if you already have a router with complete routing functions in your network.
Set Up a DSL Connection
This tutorial shows you how to set up a DSL Internet connection using the Web Configurator on DSL routers (see Overview).
If you connect to the Internet through a DSL connection, use the information from your Internet Service Provider (ISP) to configure the Broadband screens.
1 Go to Network Setting > Broadband and then the following screen appears. Click Add New WAN Interface.
2 To set the Zyxel Device to Routing mode, see Routing Mode.
To set the Zyxel Device to Bridge mode, see Bridge Mode.
Routing Mode
1 In this routing mode example, the DSL WAN connection has the following information.
General
Name
MyDSLConnection
Type
ADSL over ATM
Connection Mode
Routing
Encapsulation
PPPoE
IPv6/IPv4 Mode
IPv4
ATM PVC Configuration
VPI/VCI
36/48
Encapsulation Mode
LLC/SNAP-Bridging
Service Category
UBR without PCR
Account Information
PPP User Name
1234@DSL-Ex.com
PPP Password
ABCDEF!
Static IP Address
192.168.1.32
Gateway IP Address
192.168.1.254
Primary DNS server
192.168.5.2
Secondary DNS server
192.168.5.1
Others
Authentication Method: AUTO
PPPoE Passthrough: Disabled
NAT: Enabled
IGMP Multicast Proxy: Enabled
Apply as Default Gateway: Enabled
VLAN: Disabled
2 Enter the General and ATM PVC Configuration settings as provided above.
Set the Type to ADSL over ATM.
Set the Mode to Routing.
Choose the Encapsulation specified by your DSL service provider.
Set the IPv4/IPv6 Mode to IPv4 Only.
3 Enter the account information provided by your DSL service provider.
4 Enable Apply as Default Gateway to use this rule as your default Internet connection. Then select Use Following Static DNS Address and enter the DNS server addresses provided by your DSL service provider.
5 For the rest of the fields, use the default settings.
6 Click Apply to save your settings.
The new connection is displayed on the Broadband screen.
Bridge Mode
1 In this bridge mode example, the DSL WAN connection has the following information.
General
Name
MyDSLConnection
Type
ADSL over ATM
Connection Mode
Bridge
VPI/VCI
36/48
Encapsulation Mode
LLC/SNAP-BRIDGING
Service Category
UBR without PCR
3 For the rest of the fields, use the default settings.
4 Click Apply to save your settings.
5 Try to connect to a website to see if you have correctly set up your Internet connection.
Set Up a GPON Connection
If you connect to the Internet through a GPON connection, you need to connect a broadband modem or router with Internet access to the WAN GPON port on the Zyxel Device. You need to configure the Internet settings from the broadband modem or router on the Zyxel Device. First, make sure you have Internet access through the broadband modem or router by connecting directly to it.
1 Make sure you have the GPON WAN port connect to a modem or router.
2 Register the GPON serial number on the back label of the Zyxel Device (ONT, Optical Network Terminal) with your Internet service provider (OLT, Optical Line Terminal). The LED indicator will show the status of the registration. The GPON registration process includes the states below for the Zyxel Device:
State
DESCRIPTION
O1
Initial State: Check if the GPON port of the Zyxel Device (ONT) is enabled and ready to connect to the Internet service provider (OLT).
O2
Standby State: The Zyxel Device (ONT) is trying to receive signals sent by the Internet service provider (OLT) and is responding.
O3
Serial Number State: The Internet service provider (OLT) is sending a serial number request for the Zyxel Device (ONT). The Zyxel Device (ONT) replies with the GPON serial number found on the back label of the Zyxel Device.
O4
Ranging State: The Internet service provider (OLT) is sending a ranging request to the Zyxel Device (ONT) and is asking for a response.
O5
Operation State: The GPON connection is established between the Zyxel Device (ONT) and the Internet service provider (OLT).
See LED Indicators Panel for more information about the LED of GPON registration.
3 Go to Network Setting > Broadband and then the following screen appears. Click Add New WAN Interface.
4 To set the Zyxel Device to Routing mode, see Routing Mode.
To set the Zyxel Device to Bridge mode, see Routing Mode.
Routing Mode
1 In this routing mode example, the PON WAN connection has the following information.
General
Name
GPON-1
Type
GPON
Connection Mode
Routing
Encapsulation
IPoE
IPv6/IPv4 Mode
IPv4 Only
Others
NAT: Enabled
VLAN: Enabled
2 Enter the General settings as provided above.
Enter a Name to identify your WAN connection.
Set the Type to GPON.
Choose the Encapsulation specified by your GPON service provider.
3 Under Routing Feature, enable NAT and Apply as Default Gateway.
4 For the rest of the fields, use the default settings.
5 Click Apply to save your settings.
6 Try to connect to a website to see if you have correctly set up your Internet connection. Go to the Network Setting > Broadband screen to view the established Ethernet connection. The new connection is displayed on the Broadband screen
Bridge Mode
1 In this bridge mode example, the GPON WAN connection has the following information.
General
Name
GPON-2
Type
GPON
Connection Mode
Bridge
2 Enter the General settings provided by your Internet service provider.
Set your GPON connection Mode to Bridge.
Set Up an Ethernet Connection
If you connect to the Internet through an Ethernet connection, you need to connect a broadband modem or router with Internet access to the WAN Ethernet port on the Zyxel Device. You need to configure the Internet settings from the broadband modem or router on the Zyxel Device. First, make sure you have Internet access through the broadband modem or router by connecting directly to it.
This example shows you how to configure an Ethernet WAN connection.
1 Make sure you have the Ethernet WAN port connect to a modem or router.
2 Go to Network Setting > Broadband and then the following screen appears. Click Add New WAN Interface to add a WAN connection.
3 To set the Zyxel Device to Routing mode, see Routing Mode.
Routing Mode
1 In this routing mode example, configure the following information for the Ethernet WAN connection.
General
Name
My ETH Connection
Type
Ethernet
Connection Mode
Routing
Encapsulation (Internet Type)
IPoE
IPv6/IPv4 Mode
IPv4 Only
Set the Type to Ethernet.
Set your Ethernet connection Mode to Routing.
Choose the Encapsulation specified by your Internet service provider. For this example, select IPoE as the WAN encapsulation type.
6 Go to the Network Setting > Broadband screen to view the established Ethernet connection. The new connection is displayed on the Broadband screen.
Bridge Mode
1 In this bridge mode example, configure the following information for the Ethernet WAN connection.
General
Name
My ETH Connection
Type
Ethernet
Connection Mode
Bridge
Set your Ethernet connection Mode to Bridge.
Wi-Fi Network Setup
For Zyxel Devices that support MPro Mesh, you can use the MPro Mesh app or the Zyxel One app to configure your Wi-Fi network. See Overview for setting up your Wi-Fi network with the Zyxel One app.
In this example, you want to set up a Wi-Fi network so that you can use your notebook to access the Internet. In this Wi-Fi network, the Zyxel Device is an access point (AP), and the notebook is a Wi-Fi client. The Wi-Fi client can access the Internet through the AP.
Wi-Fi Network Setup
See the label on the Zyxel Device for the Wi-Fi network settings and then connect manually to the Zyxel Device. Alternatively, you can connect to the Zyxel Device Wi-Fi network using WPS. See Connect to the Zyxel Device’s Wi-Fi Network Using WPS.
Change the Zyxel Device Wireless Network Name (SSID)
You set up the Zyxel Device at home but have trouble finding its Wi-Fi network among many nearby networks. To make it easier to identify, you can change the default Wireless Network Name.
To modify the Wireless Network Name, follow the steps below:
2 Go to Network Setting > Wireless > General.
3 In Wireless Network Setup, select the Band you want to change the Wireless Network Name in the drop down list.
4 In Wireless Network Settings, enter the new Wi-Fi network name in the Wireless Network Name field. You can use up to 32 printable characters, including spaces. In the example below, the 2.4GHz Wi-Fi network is renamed to “Julie’s Wi-Fi_2.4G”.
5 When finished, scroll down and click Apply.
6 Click the menu icon () in the upper right corner, and then click Connection Status.
7 In the Wi-Fi Settings section, your new 2.4GHz Wi-Fi Name is now set to “Julie’s Wi-Fi_2.4G”.
Change the Zyxel Device Wi-Fi Password
You set up the Zyxel Device at home but have trouble remembering the complicated default Wi-Fi Password on the device label. To make it easier to remember, you can change the default Wi-Fi Password. Changing the Zyxel Device Wi-Fi Password regularly can also enhance your Wi-Fi network’s security and privacy.
To change the Zyxel Device Wi-Fi Password, follow the steps below:
3 In Security Level, select More Secure for better protection of your Wi-Fi network.
4 Choose a Security Mode from the drop-down list:
If your Wi-Fi client supports WPA3-SAE, select this mode.
If you are not sure whether your Wi-Fi client supports WPA3-SAE, select WPA3-SAE/WPA2-PSK or WPA2-PSK.
The example below uses WPA3-SAE/WPA2-PSK as the Security Mode.
5 After selecting the Security Mode, you have two methods to create a new Password.
Select the Generate password automatically checkbox to have the Zyxel Device create a Password for you.
Enter your own Wi-Fi Password. The Password must be 8 characters long and include at least 1 uppercase letter, 1 lowercase letter, 1 number, 1 special character, or 64 hexadecimal digits (“0-9”, “A-F”).
The Strength bar shows the current Password strength: weak, medium, or strong.
In the example below, the 2.4GHz Wi-Fi network’s Password has been changed to “Zyxel1234!!”.
6 Click this to view the Encryption type and set the Timer for data transmission on the Zyxel Device:
Encryption: The Zyxel Device Wi-Fi network uses AES with a 128-bit key for data encryption.
Timer: This defines how often the RADIUS server sends a new group key out to all clients.
*The Protected Management Frames field is available when using WPA2-PSK as the Security Mode with AES Encryption. Management frame protection (MFP) helps prevent Wi-Fi DoS (Denial of Service) attacks. For more details about Protected Management Frames, please refer to More Secure (Recommended).
The example below uses AES as Encryption type and sets the Timer to 3600 seconds. For more details about the Encryption settings for your Zyxel Device network, please refer to More Secure (Recommended).
7 When finished, click Apply to save the settings.
8 Click the menu icon () in the upper right corner, and then click Connection Status.
9 In the Wi-Fi Settings section, your new 2.4GHz Wi-Fi Password is now set to “Zyxel1234!!”.
Change Security Settings on a Wi-Fi Network
This example changes the default security settings of a Wi-Fi network to the following:
SSID
Example
Security Mode
WPA3-SAE/WPA2-PSK
Pre-Shared Key
Admin1234!!
802.11 Mode
802.11b/g/n Mixed
SSID
Zyxel_E1EB
Security Mode
WPA3-SAE/WPA2-PSK
Pre-Shared Key
Admin1234!!
802.11 Mode
802.11b/g/n/ax/be Mixed
1 Go to the Network Setting > Wireless > General screen. Select More Secure as the security level and WPA3-SAE/WPA2-PSK as the security mode. Configure the screen using the provided parameters. Click Apply.
2 Go to the Wireless > Others screen. Set 802.11 Mode to 802.11b/g/n Mixed, and then click Apply.
You can now use the WPS feature to establish a Wi-Fi connection between your notebook and the Zyxel Device. Now use the new security settings to connect to the Internet through the Zyxel Device using Wi-Fi.
Enhance Security Settings on a Zyxel Device Wi-Fi Network
To enhance the security of your Zyxel Device Wi-Fi network, you need to select the strongest Security Mode. To do this, follow the below steps:
1 Go to the Network Setting > Wireless > General screen. In Wireless Network Setup, select the Band you want to change the Security Mode.
This section shows you how to connect a Windows 10 notebook to the Zyxel Device’s Wi-Fi network using WPS. WPS (Wi-Fi Protected Setup) is a security standard that allows devices to connect to a router securely without having to enter a password.
WPS Push Button Configuration (PBC)
1 Make sure the Zyxel Device is turned on, and your notebook is within range of the Zyxel Device’s Wi-Fi signal.
2 Log into the Web Configurator to enable the notebook to connect to the Zyxel Device’s Wi-Fi network by pressing the WPS button on the Zyxel Device. Go to Network Setting > Wireless > WPS. Select the band you want to use to connect to the Wi-Fi network. Click the Method 1 PBC switch to the right. Click Apply.
3 In Windows 10, click the Network icon in the system tray to open the list of available Wi-Fi networks.
4 The pop-up list displays the Wi-Fi networks near you. In the screen below, locate the Zyxel Device’s Wi-Fi network, Zyxel_5791 in this example. Zyxel_5791 is the default SSID shown on the Zyxel Device label. Select the Connect automatically checkbox, and then click Connect.
5 You don’t need to enter the network security key for the Zyxel Device’s Wi-Fi network because you are using the WPS button to connect to the Zyxel Device’s Wi-Fi network.
* You must press the WPS button on the Zyxel Device within two minutes.
6 Push and hold the WPS button located on the Zyxel Device for two minutes or until the Wi-Fi or WPS LED starts blinking slowly. This allows the Zyxel Device to send the Wi-Fi network settings to Windows 10 using WPS. To see the location of the WPS button on the Zyxel Device, please refer to WPS Button.
7 Windows 10 will display Getting settings from the router.
Your Windows 10 notebook can now connect securely to the Zyxel Device Wi-Fi network.
Set Up a Guest Network
The Zyxel Device authenticates the Wi-Fi device using the PIN, and then sends the Wi-Fi network settings to the device using WPS. This process may take up to 2 minutes. The Wi-Fi device is then able to connect to the Wi-Fi network securely. A company wants to create two Wi-Fi networks for different groups of users as shown in the following figure. Each Wi-Fi network has its own SSID and security mode. Both networks are accessible on both 2.4 GHz and 5 GHz Wi-Fi bands.
Employees using the General Wi-Fi network group will have access to the local network and the Internet.
Visitors using the Guest Wi-Fi network group with a different SSID and password will have access to the Internet only.
Use the following parameters to set up the Wi-Fi network groups.
General
Guest
2.4 or 5G SSID
Employee
Guest
Security Level
More Secure
More Secure
Security Mode
WPA3-SAE/WPA2-PSK
WPA3-Personal-Transition
Pre-Shared Key
ForCompanyOnly123!
Guest123456!
General
Guest
2.4 or 5G SSID
Example
Guest
Security Level
More Secure
More Secure
Security Mode
WPA3-SAE/WPA2-PSK
WPA2-PSK
Pre-Shared Key
ForCompanyOnly123!
Guest123456!
1 Go to the Network Setting > Wireless > General screen. Use this screen to set up the company’s general Wi-Fi network group. Configure the screen using the provided parameters and click Apply. Note that if you have employees using 2.4 GHz and 5 GHz devices, enable Keep the same settings for 2.4GHz and 5GHz wireless networks to use the same SSID and password. Clear it if you want to configure different SSIDs and passwords for 2.4 GHz and 5 GHz bands.
2 Go to the Network Setting > Wireless > Guest/More AP screen. Click the Modify icon to configure the second Wi-Fi network group. A Home Guest can access the Internet and other Home Guest Wi-Fi clients on the same Wi-Fi network. They cannot communicate with wired devices connected to the Zyxel Device’s LAN. An External Guest can just access the Internet through the Zyxel Device.
3 On the Guest/More AP screen, click the Modify icon to configure the other Guest Wi-Fi network group. Configure the screen using the provided parameters and click OK.
4 Check the status of Guest in the Guest/More AP screen. A yellow bulb under Status means the SSID is active and ready for Wi-Fi access.
Set Up Two Guest Wi-Fi Networks on Different Wi-Fi Bands
In this example, a company wants to create two Guest Wi-Fi networks: one for the Guest group and the other for the VIP group as shown in the following figure. Each network will have its SSID and security mode to access the internet.
The Guest group will use the 2.4 GHz band.
The VIP group will use the 5 GHz band.
The Company will use the following parameters to set up the Wi-Fi network groups.
Wi-Fi Settings Parameters Example
Band
2.4 GHz
5 GHz
SSID
Guest
VIP
Security Mode
WPA2-PSK
WPA3-SAE/WPA2-PSK
Pre-Shared Key
Guest123456!
Zyxel1234@@!
1 Go to the Wireless > General screen and set Band to 2.4GHz to configure 2.4 GHz Guest Wi-Fi settings for Guest. Click Apply.
*You will not be able to configure the 2.4 GHz and 5 GHz Guest Wi-Fi settings separately if Keep the same settings for 2.4GHz and 5GHz wireless networks is enabled.
2 Go to the Wireless > Guest/More AP screen and click the Modify icon. The following screen appears. Configure the Security Mode and Password using the provided parameters and click OK.
The 2.4 GHz Guest Wi-Fi network is now configured.
3 Go to the Wireless > General screen and set Band to 5GHz to configure the 5G Guest Wi-Fi settings for VIP. Click OK.
4 Go to the Wireless > Guest/More AP screen and click the Modify icon. The following screen appears. Configure the Security Mode and Password using the provided parameters and click OK.
The 5G VIP Wi-Fi network is now configured.
Configure the Channel and Bandwidth for Each Wi-Fi Band
For optimal Wi-Fi network performance, you can change the bandwidth and channel for a specific band to improve the throughput and minimize the interference. You can refer to Recommended Application for Each Band for the recommended setup.
In this tutorial, you want to configure the channel to 6 and bandwidth to 20 MHz for 2.4 GHz band.
1 Go to Network Setting > Wireless > General.
2 In Band, select 2.4GHz from the drop-down list.
3 In Bandwidth, select 20MHz from the drop-down list.
4 In Channel, select 6 from the drop-down list.
The table below shows the recommended application for each band, along with the suggested channel and bandwidth.
Band
Bandwidth
channel
Application
2.4 GHz
20 MHz
1, 6, 11
Web browsing, email, IoT (Internet of Things)
5 GHz
40 MHz
36, 40, 44, 48
HD streaming, online meetings
80 MHz
36, 40, 44, 48 or 52-128
4K or 8K streaming, multiplayer gaming
*If you are still unsure about this configuration, you can set the Channel to Auto, allowing the Zyxel Device to automatically determine the proper channel for the selected band.
Set Up a Cellular Network Connection
You can set up a cellular WAN connection as a backup if the primary WAN connection fails. To do this, use a cellular dongle and your Internet Service Provider’s (ISP) information to configure the Zyxel Device. The WAN connection priority of the Zyxel Device is listed below from highest to lowest:
Zyxel Device WAN Connection Priority
ax Series
dx Series
EX Series
px Series
SFP
SFP
SFP
PON WAN
Ethernet WAN
DSL
Ethernet WAN
Ethernet WAN
Cellular WAN
Ethernet WAN
Cellular WAN
Cellular WAN
Cellular WAN
*Disconnect the DSL and Ethernet WAN ports to use the cellular dongle as your primary WAN connection, as the Zyxel Device automatically uses a wired WAN connection when available.
To set up the cellular WAN with a cellular dongle, follow the steps below:
1 Connect a cellular dongle to the USB port on the Zyxel Device.
2 Log into the Web Configurator. Go to Network Setting > Broadband > Cellular Backup.
3 In General, click the Cellular Backup switch to the right to have the Zyxel Device use the cellular connection as your WAN or a backup when the wired WAN connection fails.
4 Click the Ping Check switch to the right to have the Zyxel Device verify the primary WAN connection status with a ping test. You can configure the ping frequency and the number of consecutive failures before triggering cellular backup. Select Ping Default Gateway to have the Zyxel Device ping the default gateway IP address of the primary WAN interface.
5 In Cellular Connection Settings, enter the SIM card information your ISP provides. Select On Demand in the Connection drop-down list and enter 60 in the Max Idle Timeout field to disconnect the cellular WAN after the connection is idle for 60 minutes. Select Obtain an IP Address Automatically and Obtain DNS Info Dynamically to automatically get the IP address and DNS server addresses from your ISP.
6 To notify clients when the cellular connection is activated, click the Enable e-mail Notification switch to the right. In the below example, select the Mail Account myemailaddress@gmail.com configured in Maintenance > E-mail Notification. Set Cellular Backup as the Cellular Backup e-mail Title and enter employee1@gmail.com in the Send Notification to E-mail field.
*Entering the PIN code incorrectly three times will lock the SIM card in your cellular dongle.
7 Click this icon to show the Budget Setup section. Click the Enable Budget Control switch to the right to enable Budget Setup. In the example below, Time Budget is set to 10 hours per month and Data Budget is set to 100 Mbytes (Download/Upload) per month for the installed SIM card.
8 Select last in the drop-down list to Reset all budget counters on last day of the month for the Zyxel Device. You can go to Maintenance > Time to configure the Zyxel Device’s time server.
9 In the example below, select the checkboxes and enter 30 for the Time Budget and Data Budget percentages in Actions before over budget. In the Current Cellular Connection Actions drop-down list, select Drop to disconnect the Current Cellular Connection when it exceeds the budget.
10 To notify clients when the cellular connection exceeds the budget, click the Enable e-mail Notification switch to the right. In the below example, select the Mail Account myemailaddress@gmail.com configured in Maintenance > E-mail Notification. Set Cellular Backup as the Cellular Backup e-mail Title and enter employee1@gmail.com in the Send Notification to E-mail field. Select the Enable Log: Interval checkbox and set 10 minutes as the interval for sending log e-mails.
The cellular WAN connection may not disconnect immediately after the Time Budget or Data Budget is reached.
11 When you finish all the configurations, click Apply. For more details about cellular backup, please refer to Cellular Backup.
USB Applications
File Sharing
This section shows you how to create a shared folder on your Zyxel Device through a USB device and allow others to access the shared folder with File Sharing services.
Set Up File Sharing on Your Zyxel Device
1 Before enabling file sharing in the Zyxel Device, please set up your shared folders beforehand in your USB device.
2 Connect your USB device to the USB port of the Zyxel Device.
3 Go to the Network Setting > USB Service > File Sharing screen. Enable File Sharing Services and click Apply to activate the file sharing function. The Zyxel Device automatically adds your USB device to the Information table.
4 Click + Add New Share to add a new share.
5 The Add New Share screen appears.
Select your USB device from the Volume drop-down list box.
Enter a Description name for the added share to identify the device.
Click Browse and the Browse Directory screen appears.
On the Browse Directory screen, select the folder that you want to add as a share. In this example, select BobShare and then click OK.
In Access Level, select Public to let the share to be accessed by all users connected to the Zyxel Device. Otherwise, select Security to let the share to be accessed by specific users to access only. Click OK to save the settings.
6 To set Access level to Security, you need to create one or more users accounts. Under Account Management, click + Add New User to open the User Account screen.
7 After you create a new user account, the screen looks like the following.
8 File sharing is now configured. You can see the USB storage device listed in the table below.
Access Your Shared Files From a Computer
You can use Windows Explorer to access the USB storage devices connected to the Zyxel Device.
*This example shows you how to use Microsoft Windows 10 to browse shared files in a share called (usb1_sda)Zoeys file. Refer to your operating system’s documentation for how to browse your file structure.
1 Open Windows Explorer.
2 In the Windows Explorer’s address bar, enter a double backslash “\\” followed by the IP address of the Zyxel Device (the default IP address of the Zyxel Device is 192.168.1.1
3 Double-click on (usb1_sda)Zoeys file, and then enter the share's username and password if prompted.
4 After you access (usb1_sda)Zoeys file through your Zyxel Device, you do not have to log in again unless you restart your computer.
Media Server
Use the media server feature to play files on a computer or on your television.
This section shows you how the media server feature works using the following:
Microsoft (MS) Windows Media Player
Media Server works with Windows 10. Make sure your computer is able to play media files (music, videos and pictures).
A digital media adapter
You need to set up the media adapter to work with your television (TV).
Before you begin, connect the USB storage device containing the media files you want to play to the USB port of your Zyxel Device.
Configure the Zyxel Device as a Media server
To use your Zyxel Device as a media server, follow the steps below.
1 Go to the Network Setting > USB Service > Media Server screen.
2 Enable Media Server, and then select an interface on which you want to enable the media server function.
3 Enter the path clients use to access the media files on a USB storage device connected to the Zyxel Device, and click Apply.
This enables DLNA-compliant media clients to play the video, music and image files in your USB storage device.
Playing Media Using Windows Media Player on Windows 10
This section shows you how to play the media files on the USB storage device connected to your Zyxel Device using Windows Media Player.
1 Open Windows Media Player. It automatically detects the Zyxel Device.
2 If you cannot see the Zyxel Device in the left panel as shown above, go to Organize > Manage Libraries > Music > Add on the Windows Media Player Home screen. In the Windows Explorer’s address bar, enter \\192.168.1.1 . The following screen appears. Select the folder containing the media you wish to upload to Windows Media Player, and then click Include Folder.
3 Select the shared folder, and then click Add to add it to your Media Library. Click OK to save the settings.
4 In the right panel, you can browse and play the files available in the USB storage device based on the category (Music, Video, Pictures, Recorded TV) you selected.
Using a Digital Media Player
This section shows you how you can use the Zyxel Device with a hardware digital media player to play media files stored in the USB storage device on your TV screen.
*For this tutorial, your digital media player is already connected to the TV.
1 Connect the digital media player to an available LAN port on your Zyxel Device.
2 Turn on the TV and wait for the digital media player Home screen to appear. Select the Zyxel Device as your media server.
3 The screen shows you the list of available media files in the USB storage device. Select the file you want to open and push the Play button on the remote control.
Network Security
Configure a Firewall Rule
You can enable the firewall to protect your LAN computers from malicious attacks from the Internet.
1 Go to the Security > Firewall > General screen.
2 Select IPv4 Firewall/IPv6 Firewall to enable the firewall, and then click Apply.
3 Open the Access Control screen, click + Add New ACL Rule to create a rule.
4 Use the following fields to configure and apply a new ACL (Access Control List) rule.
Active: Click this button to the right to enable this rule.
Filter Name: Enter a name to identify the firewall rule.
Source IP Address: Enter the IP address of the computer that initializes traffic for the application or service.
Destination IP Address: Enter the IP address of the computer to which traffic for the application or service is entering.
Protocol: Select the protocol (ALL, TCP/UDP, TCP, UDP, ICMP or ICMPv6) used to transport the packets.
Policy: Select whether to (ACCEPT, DROP, or REJECT) the packets.
Direction: Select the direction (WAN to LAN, LAN to WAN, WAN to ROUTER, or LAN to ROUTER) of the traffic to which this rule applies.
5 Select Enable Rate Limit to limit the number of requests a client can make within a specific time period. Click OK.
Configure a Schedule for Firewall ACL Rules
This section shows you how to create a Scheduler Rule and apply it to a Firewall ACL Rule to block employees’ access to Youtube during work hours.
Add New Scheduler Rule screen
1 Go to Security > Scheduler Rule > + Add New Rule
2 In the Add New Schedule Rule screen:
Enter WorkHours for the Rule Name.
Under Day, select Monday to Friday.
Set Time of Day Range to 08:00 to 18:00.
Click OK to save.
Add New ACL Rule Screen
3 Go to Security > Firewall > Access Control > + Add New ACL Rule
4 In the Add New ACL Rule screen:
Click the Active button to the right to enable this rule.
Enter YT_WorkHours for the Filter Name.
Set Source IP Address to your office’s internal network.
Use nslookup to find Youtube’s IP address and set the Destination IP Address accordingly.
Select TCP for Protocol.
Set Custom Destination Port to 443.
Select REJECT for Policy to discard the packets.
Set Direction to LAN to WAN.
Under Scheduler Rules, select WorkHours that you created earlier.
Click OK.
Youtube access will now be blocked from 08:00 to 18:00, Monday to Friday.
Set Up Home Security
This section shows you how to use Home Security to block social media at all times.
1 Go to Security > Home Security to open the Connected Home Security screen.
2 Enter Facebook’s domain name (e.g., facebook.com) in the Enter Website URL field, then click Block.
3 The domain name will appear in the Block List below. Facebook will now be blocked for all devices on your network.
Set Up Parental Control
This section shows you how to configure PC to restrict access to certain Internet websites.
*The style and features of your parental control vary depending on the Zyxel Device you are using.
Configure Parental Control Schedule and Filter
Parental Control Profile (PCP) allows you to set up a rule for:
Internet usage scheduling.
Websites and URL keyword blocking.
Use this feature to:
Limit the days and times a user can access the Internet.
Limit the websites a user can access on the Internet.
This example shows you how to block a user from accessing the Internet during time for studying. It also shows you how to stop a user from accessing specific websites.
Use the parameters below to configure a schedule rule and a URL keyword blocking rule.
profile name
INTERNET ACCESS schedule
network service
Site / url keyword
Study
Day:
Monday to Friday
Time:
8:00 to 11:00
13:00 to 17:00
Network Service Setting:
Block
Service Name:
HTTP
Protocol:
TCP
Port:
80
Block or Allow the Web Site:
Block the web URLs
Website:
gambling
Parental Control Screen
Open the Parental Control screen. Select Enable under General to enable parental control. Then click + Add New PCP to add a rule.
Add New PCP Screen
1 Go to Parental Control > Add New PCP. Under General:
Select Enable to enable the rule you are configuring.
Enter the Parental Control Profile Name given in the above parameter.
Select an user this rule applies to in Home Network User, then click Add. You will see the MAC address of the user you just select in Rule List.
2 Under Internet Access Schedule:
Click + Add New Time to add a second schedule.
Use the parameter given above to configure the time settings of your schedule.
3 Under Network Service:
In Network Service Setting, select Block.
Click + Add New Service, then use the parameter given above to configure settings for the Internet service you are blocking.
4 Under Site / URL Keyword:
Select Block the web URLs in Block or Allow the Web Site.
Click Add, then use the parameter given above to configure settings for the URL keyword you are blocking.
Select Redirect blocked site to Zyxel Family Safety page to redirect the web browser to the Zyxel Family Safety page if he or she tries to access a website with the blocked URL keyword.
5 Click OK to save your settings.
Configuring a Parental Control Schedule
Parental Control Profile allows you to set up a schedule rule for Internet usage. Use this feature to limit the days and times a user can access the Internet.
This example shows you how to block an user from accessing the Internet during time for studying. Use the parameter below to configure a schedule rule.
profile name
start blocking
end blocking
repeat on
Study
8:00 am
11:00 am
from Monday to Friday
1:00 pm
5:00 pm
1 Click Add more Profile to open the Parental Control screen.
2 Use this screen to add a Parental Control rule.
Enter the Profile Name given in the above parameter.
Click on the switch to enable Profile Active.
Select a device, and then click Next to proceed.
3 Use this screen to edit the Parental Control schedule.
Click Add New Schedule to add a second schedule.
Use the parameter given above to configure the time settings of your schedules.
Click Save to save the settings.
Configure a MAC Address Filter for Wired LAN Connections
You can use a MAC address filter to exclusively allow or permanently block someone from the wired LAN network.
This example shows that computer B is not allowed access to the wired LAN network.
Configure a MAC Address Filter Example
1 Go to the Security > MAC Filter > MAC Filter screen. Under MAC Address Filter, select Enable.
2 Under MAC Restrict Mode, select Deny to block access from computer B.
3 Under Add New Rule, select Custom to enter the MAC address of computer B. Click Add to add a new entry.
4 Select Active, and then enter the Host Name and MAC Address of computer B. Click Apply.
*Make sure that the check box under Active is selected.
Configure a MAC Address Filter for Wi-Fi Clients
This section shows you how to deny or allow specific Wi-Fi clients to access the Wi-Fi network.
Deny Access
This example shows that smartphone C is not allowed access to the Wi-Fi network.
If you want to block access from smartphone C, follow the steps below:
1 Log into the Web Configurator of your Zyxel Device. Go to Connectivity > Wi-Fi screen to find the MAC address of smartphone C.
2 Go to Network Setting > Wireless > MAC Authentication screen. Under General, select the Band and SSID of the Wi-Fi network that smartphone C is using.
3 Under MAC Restrict Mode, select Deny to block smartphone C from accessing your Wi-Fi network.
4 Click + Add new MAC address and select Custom to enter the MAC address of smartphone C.
5 Click Apply. Now smartphone C will not be able to join the Wi-Fi network.
Allow Access
This example shows that only smartphone C is given access to the Wi-Fi network.
If you want to permit access from smartphone C, follow the steps below:
1 Find the MAC address of smartphone C. For the iOS system, go to Settings > General > About > Wi-Fi Address. For Android system, go to Settings > About device > Status > Device MAC Address.
2 Log into the Web Configurator of your Zyxel Device. Go to Network Setting > Wireless > MAC Authentication screen. Under General, select the Band and SSID of the Wi-Fi network that you want to allow smartphone C to connect to.
3 Under MAC Restrict Mode, select Allow to give smartphone C access to the Wi-Fi network.
5 Click Apply. Now only smartphone C should be able to join the Wi-Fi network.
Secure Server Setup
Use DMZ (DeMilitarized Zone) when you want to make specific devices or servers accessible from the Internet while keeping your internal (LAN) network secure. The DMZ allows traffic from the WAN and LAN but blocks traffic from the DMZ to the LAN. This helps protect client devices within the LAN. To set up a gaming server using DMZ, follow the steps below:
1 Log into the Web Configurator. Go to Network Setting > NAT > DMZ.
2 In the Default Server Address field, enter the default public server IP address 192.168.13.11 that you set up. Click Apply.
3 To test if the server setup is successful, check the connection between the DMZ server and the LAN. Enter cmd in your client computer’s search bar, and click Command Prompt to open it.
4 The following screen appears. Enter ping 192.168.13.11 to check if the client in the LAN can access the server set up in the DMZ. The example below uses the following settings:
Client: 192.168.11.33 (LAN)
Server: 192.168.13.11 (DMZ Server)
The screen shows that ping 192.168.13.11 was successful, indicating that the connection from the LAN to the DMZ server is allowed.
5 On your DMZ server, open Command Prompt. Enter ping 192.168.11.33 to check if the DMZ server can access the client computer in the LAN. Request timed out in the screen below indicates that the DMZ server cannot ping clients within the LAN.
These two tests ensure that the DMZ server setup is complete.
Internet Calls
Configure VoIP
To make voice calls over the Internet, you must set up a Session Initiation Protocol (SIP) provider and SIP account on the Zyxel Device. You should have an account with a SIP service provider already set up.
Add a SIP Service Provider
Follow the steps below to add a SIP service provider.
1 Make sure your Zyxel Device is connected to the Internet.
2 Open the Web Configurator.
3 Go to the VoIP > SIP > SIP Service Provider screen. Click the Add New Provider button to add the SIP Service Provider.
4 On the Add New Provider screen, select Enable SIP Service Provider.
5 Enter the SIP Service Provider Name of up to 64 printable characters except [ " ], [ ` ], [ ' ], [ < ], [ > ], [ ^ ], [ $ ], [ | ], [ & ], or [ ; ].
6 Enter SIP Proxy Server Address, SIP REGISTRAR Server Address, and SIP Service Domain provided by your SIP service provider. Click OK to save your settings.
Add a SIP Account
The SIP account must be associated with the SIP service provider configured above. You may configure several SIP accounts for the same service provider. Follow the steps below to set up your SIP account:
3 Go to the VoIP > SIP > SIP Account screen.
4 Click the Add New Account button on the SIP Account screen to add a SIP account and map it to a phone port.
5 Under General, select Enable SIP Account, and then enter the SIP Account Number.
6 Under Authentication, enter Username and Password. Leave the other settings as default. Click OK to save your settings.
Configure a Phone
You must now configure the phone port to use the SIP account you just configured.
1 Go to the VoIP > Phone > Phone Device screen.
2 Click the Modify icon of PHONE1 to configure PHONE1 on your Zyxel Device. The following screen appears.
3 Under SIP1 SIP Account to Make Outgoing Call, select SIP1 to have the phone connected to the first phone port use the registered SIP1 account to make outgoing calls.
4 Under SIP Account(s) to Receive Incoming Call, select SIP1 to have the phone connected to the first phone port receive phone calls for the SIP1 account. Click OK to save your changes.
Make a VoIP Call
Follow these steps to make a phone call using Voice over IP (VoIP).
1 Make sure you connect a telephone to phone port 1 on the Zyxel Device.
2 Make sure the Zyxel Device is turned on and connected to the Internet.
3 Pick up the phone receiver.
4 Dial the VoIP phone number you want to call.
Device Maintenance
You can upgrade the Zyxel Device firmware, back up the configuration and restore the Zyxel Device to its previous or default settings.
Upgrade the Firmware
Upload the latest firmware to the Zyxel Device for feature enhancements.
1 To download the latest firmware of your Zyxel Device, go to https://www.zyxel.com/service-provider and search for your model. The latest firmware will be available under the Downloads & resources tab. The model code for the Zyxel Device in this example is v5.13(ABLZ.1). Note the model code for your Zyxel Device.
2 Unzip the file.
3 Go to the Maintenance > Firmware Upgrade screen.
4 Click Browse/Choose File and select the file with a ".bin" extension to upload. Click Upload.
5 This process may take up to 2 minutes to finish. After 2 minutes, log in again and check your new firmware version in the Connection Status screen.
Back up the Device Configuration
Back up a configuration file allows you to return to your previous settings.
1 Go to the Maintenance > Backup/Restore screen.
2 Under Backup Configuration, click Backup. A configuration file is saved to your computer. In this case, the Backup/Restore file is saved.
Restore the Device Configuration
This section shows you how to restore a previously-saved configuration file from your computer to your Zyxel Device.
2 Under Restore Configuration, click Browse/Choose File, and then select the configuration file that you want to upload. Click Upload.
3 The Zyxel Device automatically restarts after the configuration file is successfully uploaded. Wait for one minute before logging into the Zyxel Device again. Go to the Connection Status page to check the firmware version after the reboot.
How to Reset the Zyxel Device to the Factory Defaults
To reset the Zyxel Device, you can press the RESET button on the rear panel for more than 5 seconds. Alternatively, you can use the web configurator to reset the Zyxel Device.
Go to Maintenance > Backup/Restore and click the Reset All Settings / Reset button. The Zyxel Device will reset to factory defaults and the LAN IP address will be set to the default IP address.
If you want to reset the Zyxel Device while keeping the Mesh Wi-Fi Settings, click the Reset All Settings Except Mesh button. See Backup/Restore for more details.
You can configure WAN access for a specific trusted computer through HTTPS, SSH to the Zyxel Device. Remote management determines which interface and web services are allowed to access the Zyxel Device. Customer support may also request remote access to your Zyxel Device for debugging purposes.
Configure Access to Your Zyxel Device
Perform the following to configure access to your Zyxel Device:
1 Go to the Maintenance > Remote Management > MGMT Services screen. Select the WAN interface and services allowed to access the Zyxel Device remotely.
These are the different ways to access the Zyxel Device remotely.
Maintenance > Diagnostic
access type
label
Description
LAN / WLAN (Wi-Fi)
LAN / WLAN
This allows access of the selected Service from the local LAN.
WAN
WAN
This allows access of the selected Service from the WAN connections.
Trust Domain
Trust Domain
This allows access of the selected Service only from the trusted IPv4 / IPv6 addresses configured under Trust Domain.
2 Select how you want to access the Zyxel Device remotely.
3 You may change the server Port number for a service if needed, however you must use the same port number in order to use that service for remote management.
Configure the Trust Domain
Perform the following to configure the Trust Domain on your Zyxel Device:
1 Go to the Maintenance > Remote Management > Trust Domain screen. Click + Add Trust Domain to go to the Add Trust Domain screen to add a trusted host IPv4 / IPv6 address.
2 Enter a public IPv4 / IPv6 IP address which is allowed to access the service on the Zyxel Device from the WAN. Then click OK.
System Log
View System Log
To view the system log of the Zyxel Device, go to System Monitor > Log > System Log.
Select the Level to filter the log by severity. Select the Category to filter the log by different features. If you want to download the log file on your local computer, click Export Log to download the Zyxel Device's system log to your local computer.
Send the System Log through E-mail
You can also use the Web Configurator to send the system logs of the Zyxel Device to specific email addresses. Customer support may also request logs for debugging. Please follow the steps below:
1 Go to Maintenance > E-mail Notifications and click Add New e-mail to create an account to receive the log.
2 Enter the following information and click OK.
Mail Server Address: Enter the server name or the IP address of the mail server for the email address specified in the Account e-mail Address field.
Authentication Username: Enter the user name of a mail account you specified in the Account e-mail Address field.
Authentication Password: Enter the password associated with the user name above.
Account e-mail Address: Enter the email address you want to appear as the sender of the emails Zyxel Device sends.
3 You can see the account you add on the Maintenance > E-mail Notifications screen.
4 Go to Maintenance > Log Setting. Set up or enter the following information under E-mail Log Settings and click Apply.
E-mail Log Settings: Slide the switch to the right.
Mail Account: Select the server you set up in Step 2 to send the log.
Send Log to: Enter the email address to which you want to send the log.
5 Go to System Monitor > Log > System Log. Click E-mail Log Now to send the log file to the email address you specified.
