WLAN Station Status
WLAN Station Status Overview
Click System Monitor > WLAN Station Status to open the following screen. Use this screen to view information and status of the Wi-Fi stations (Wi-Fi clients) that are currently associated with the Zyxel Device. Being associated means that a Wi-Fi client (for example, your computer with a Wi-Fi network card installed) has connected successfully to an AP (or Wi-Fi router) using the same SSID, channel, and Wi-Fi security settings.
System Monitor > WLAN Station Status (For 2.4 GHz and 5 GHz models)
System Monitor > WLAN Station Status (for 2.4 GHz, 5 GHz, and 6 GHz models)
Label
Description
Refresh Interval
Select how often you want the Zyxel Device to update this screen.
This is the index number of an associated Wi-Fi station.
MAC Address
This field displays the MAC address of an associated Wi-Fi station.
Rate (Mbps)
This field displays the transmission rate of Wi-Fi traffic between an associated Wi-Fi station and the Zyxel Device.
RSSI (dBm)
The RSSI (Received Signal Strength Indicator) field shows the Wi-Fi signal strength of the station’s Wi-Fi connection.
The normal range is –30dBm to –79dBm. If the value drops below –80dBm, try moving the associated Wi-Fi station closer to the Zyxel Device to get better signal strength.
SNR
The Signal-to-Noise Ratio (SNR) is the ratio between the received signal power and the received noise power. The greater the number, the better the quality of Wi-Fi.
The normal range is 15 to 40. If the value drops below 15, try moving the associated Wi-Fi station closer to the Zyxel Device to get better quality Wi-Fi.
Level
This field displays a number which represents the strength of the Wi-Fi signal between an associated Wi-Fi station and the Zyxel Device. The Zyxel Device uses the RSSI and SNR values to determine the strength of the Wi-Fi signal.
5 means the Zyxel Device is receiving an excellent Wi-Fi signal.
4 means the Zyxel Device is receiving a very good Wi-Fi signal.
3 means the Zyxel Device is receiving a weak Wi-Fi signal,
2 means the Zyxel Device is receiving a very weak Wi-Fi signal.
1 means the Zyxel Device is not receiving a Wi-Fi signal.
Channel
This field displays the wireless channel bandwidth of an associated Wi-Fi station.
Connection Uptime
This field displays the connection duration of the client devices currently linked to the Zyxel Device.
