LABEL | Description |
Status | |
Data Unit | Select the unit for the number of bytes sent and received on the Zyxel Device. You can choose Byte, KB, MB, or GB from the drop-down list. Use a larger unit (gigabytes, megabytes, kilobytes, or bytes) if you have a lot of traffic in your network. |
Refresh Interval | Select how often you want the Zyxel Device to update this screen. |
Connected Interface | This shows the name of the WAN interface that is currently connected. |
Packets Sent | |
Data | This indicates the number of transmitted packets on this interface. |
Error | This indicates the number of frames with errors transmitted on this interface. |
Drop | This indicates the number of outgoing packets dropped on this interface. |
Packets Received | |
Data | This indicates the number of received packets on this interface. |
Error | This indicates the number of frames with errors received on this interface. |
Drop | This indicates the number of received packets dropped on this interface. |
Disabled Interface | This shows the name of the WAN interface that is currently disabled. |
Packets Sent | |
Interface | This shows the LAN or WLAN interface. |
Bytes / KB / MB / GB Sent | Byte: This indicates the number of bytes sent on this interface. KB: This indicates the number of kilobytes sent on this interface. MB: This indicates the number of megabytes sent on this interface. GB: This indicates the number of gigabytes sent on this interface. |
Bytes / KB / MB / GB Received | Byte: This indicates the number of bytes received on this interface. KB: This indicates the number of kilobytes received on this interface. MB: This indicates the number of megabytes received on this interface. GB: This indicates the number of gigabytes received on this interface. |
Interface | This shows the LAN or WLAN interfaces. |
Sent (Packets) | |
Received (Packets) | |
Device Name | This displays the name of the connected host. |
IPv4 Address | This displays the IP address of the connected host. |
MAC Address | This displays the MAC address of the connected host. |
No. of Open Sessions | This displays the number of NAT sessions currently opened for the connected host. |
Total | This displays what percentage of NAT sessions the Zyxel Device can support is currently being used by all connected hosts. You can also see the number of active NAT sessions and the maximum number of NAT sessions the Zyxel Device can support |
