label | Description |
Destination | This indicates the destination IPv4 address or IPv6 address and prefix of this route. |
Gateway | This indicates the IPv4 address or IPv6 address of the gateway that helps forward this route’s traffic. |
Subnet Mask | This indicates the destination subnet mask of the IPv4 route. |
Interface | This indicates the name of the interface through which the route is forwarded. • brx indicates a LAN interface where x can be 0 – 3 to represent LAN1 to LAN4 respectively. • ptm0 indicates a VDSL (including G.fast) WAN interface using IPoE or in bridge mode. • ethx indicates an Ethernet WAN interface using IPoE or in bridge mode. • ppp0 indicates a WAN interface using PPPoE. • wlx indicates a wireless interface where x can be 0 – 1. |
