Label | Description |
Monitor | |
Refresh Interval | Select how often you want the Zyxel Device to update this screen. Select None to stop refreshing. |
Status | |
Cellular Status | This field displays the status of the cellular Internet connection. This field can display: GSM – Global System for Mobile Communications, 2G GPRS – General Packet Radio Service, 2.5G EDGE – Enhanced Data rates for GSM Evolution, 2.75G WCDMA – Wideband Code Division Multiple Access, 3G HSDPA – High-Speed Downlink Packet Access, 3.5G HSUPA – High-Speed Uplink Packet Access, 3.75G HSPA – HSDPA+HSUPA, 3.75G |
Service Provider | This field displays the name of the service provider. |
Signal Strength | This field displays the strength of the signal in dBm. |
Connection Uptime | This field displays the time the connection has been up. |
Cellular Card Manufacturer | This field displays the manufacturer of the cellular card. |
Cellular Card Model | This field displays the model name of the cellular card. |
Cellular Card F/W Version | This field displays the firmware version of the cellular card. |
SIM Card IMSI | The International Mobile Subscriber Identity or IMSI is a unique identification number associated with all cellular networks. This number is provisioned in the SIM card. |
VID/PID | This field displays the USB Vendor ID and Product ID of the cellular card. |
