Label | Description |
IGMP/MLD Configuration | |
Default Version | Enter the version of IGMP (1~3) and MLD (1~2) that you want the Zyxel Device to use on the WAN. |
Query Interval | Enter the number of seconds the Zyxel Device sends a query message to hosts to get the group membership information. |
Query Response Interval | Enter the maximum number of seconds the Zyxel Device can wait for receiving a General Query message. Multicast routers use general queries to learn which multicast groups have members. |
Last Member Query Interval | Enter the maximum number of seconds the Zyxel Device can wait for receiving a response to a Group-Specific Query message. Multicast routers use group-specific queries to learn whether any member remains in a specific multicast group. |
Robustness Value | Enter the number of times (1~7) the Zyxel Device can resend a packet if packet loss occurs due to network congestion. |
Maximum Multicast Groups | Enter a number to limit the number of multicast groups an interface on the Zyxel Device is allowed to join. Once a multicast member is registered in the specified number of multicast groups, any new IGMP or MLD join report frames are dropped by the interface. |
Maximum Multicast Data Sources(for IGMPv3) | Enter a number to limit the number of multicast data sources (1-24) a multicast group is allowed to have. |
Maximum Multicast Group Members | Enter a number to limit the number of multicast members a multicast group can have. |
Fast Leave Enable | Select this option to set the Zyxel Device to remove a port from the multicast tree immediately (without sending an IGMP or MLD membership query message) once it receives an IGMP or MLD leave message. This is helpful if a user wants to quickly change a TV channel (multicast group change) especially for IPTV applications. |
LAN to LAN (Intra LAN) Multicast Enable | Select this to enable LAN to LAN IGMP snooping capability. |
Membership Join Immediate (IPTV) | Select this to have the Zyxel Device add a host to a multicast group immediately once the Zyxel Device receives an IGMP or MLD join message. |
Cancel | Click Cancel to exit this screen without saving. |
Apply | Click Apply to save your changes back to the Zyxel Device. |
