Administrator Account | 4 |
User Account | 4 |
administrator | user | ||
Wizard | |||
Quick Start | YES | NO | |
Configuration | |||
Connection Status | YES | YES | |
Network | |||
Broadband | YES | NO | |
Wireless | YES | NO | |
Home Networking | YES | NO | |
Routing | YES | NO | |
QoS | YES | NO | |
NAT | YES | NO | |
DNS | YES | NO | |
IGMP/MLD | YES | NO | |
Interface Grouping | YES | NO | |
USB Service | YES | NO | |
Security | |||
Firewall | YES | NO | |
Mac Filter | YES | NO | |
Home Security | YES | NO | |
Parental Control | YES | NO | |
Scheduler Rule | YES | NO | |
Certificates | YES | NO | |
VoIP | |||
Phone | YES | NO | |
Call Rule | YES | NO | |
Call History | YES | NO | |
System Monitor | |||
Log | YES | YES | |
Traffic Status | YES | YES | |
VoIP Status | YES | NO | |
ARP Table | YES | YES | |
Routing Table | YES | YES | |
xDSL Statistics | YES | YES | |
Multicast Status | YES | YES | |
WLAN Station Status | YES | YES | |
Maintenance | |||
System | YES | NO | |
User Account | YES | YES | |
Remote Management | YES | YES | |
Time | YES | YES | |
Email Notification | YES | YES | |
Log Setting | YES | YES | |
Firmware Upgrade | YES | YES | |
Backup/Restore | YES | YES | |
Reboot | YES | YES | |
Diagnostic | YES | YES | |
Label | Description |
Add New Account | Click this button to add a new user account. You can create up to four accounts in total for the admin and user groups. An admin or user account cannot belong to more than one group. |
# | This is the index number. |
Active | This indicates whether the user account is active or not. The checkbox is selected when the user account is enabled. It is cleared when it is disabled. |
User Name | This displays the name of the account used to log into the Zyxel Device Web Configurator. |
Retry Times | This displays the number of times consecutive wrong passwords can be entered for this account. 0 means there is no limit. |
Idle Timeout | This displays the length of inactive time before the Zyxel Device will automatically log the user out of the Web Configurator. |
Lock Period | This field displays the length of time a user must wait before attempting to log in again after a number of consecutive wrong passwords have been entered as defined in Retry Times. |
Group | This field displays this user has Administrator privileges. |
Remote Privilege | This field displays whether this user can access the Zyxel Device with HTTP, Telnet or SSH through the WAN, LAN or LAN/WAN. |
Modify | Click the Edit icon to configure the entry. Click the Delete icon to remove the entry. |
Cancel | Click Cancel to restore your previously saved settings. |
Apply | Click Apply to save your changes. |
Label | Description | |
Active | Click to enable (switch turns blue) or disable (switch turns gray) to activate or deactivate the user account. | |
User Name | Enter a name for this account. You can use up to 31 printable characters except [ " ], [ ` ], [ ' ], [ < ], [ > ], [ ^ ], [ $ ], [ | ], [ & ], or [ ; ]. Spaces are allowed. | |
Password | Enter your new system password. The password must contain at least one numeric and one alphabetic character. You can use 6 – 64 alphanumeric (0-9, a-z, A-Z) and special characters except [ " ], [ ` ], [ ' ], [ < ], [ > ], [ ^ ], [ $ ], [ | ], [ & ], or [ ; ]. Spaces are allowed. Note that as you type a password, the screen displays a (*) for each character you type. After you change the password, use the new password to access the Zyxel Device. If you are changing your existing password, you have to first enter your Old Password then enter your New Password. | |
Verify Password | Enter the new password again for confirmation. | |
Retry Times | Enter the number of times consecutive wrong passwords can be entered for this account. 0 means there is no limit. | |
Idle Timeout | Enter the length of inactive time before the Zyxel Device will automatically log the user out of the Web Configurator. | |
Lock Period | Enter the length of time a user must wait before attempting to log in again after a number of consecutive wrong passwords have been entered as defined in Retry Times. | |
Group | Specify whether this user will have Administrator or User privileges. An Administrator account can access all Web Configurator menus. A User account can only access System Monitor and Maintenance menus. The maximum account number of Administrator and User are both four. The total number of the users allowed to log in the Zyxel Device at the same time is eight. | |
An Administrator account can configure the following menus: | ||
Wizard | ||
Network Setting | Broadband, Wireless, Home Networking, Routing, QoS, NAT, DNS, IGMP/MLD, Vlan Group, Interface Grouping, USB Service | |
Security | Firewall, MAC Filter, Home Security, Parental Control, Scheduler Rule, Certificates | |
VoIP | SIP, Phone, Call Rule, Call History | |
System Monitor | Log, Traffic Status, VoIP Status, ARP Table, Routing Table, Multicast Status, WLAN Station Status, Cellular Statistics, Optical Signal Status | |
Maintenance | System, User Account, Remote Management, Time, Email Notification, Log Setting, Firmware Upgrade, Backup/Restore, Reboot, Diagnostic | |
A User account can configure the following menus: | ||
Maintenance | User Account, Remote Management, Time, Email Notification, Log Setting, Firmware Upgrade, Backup/Restore, Reboot, Diagnostic | |
Remote Privilege | Select whether this user can access the Zyxel Device with HTTP, Telnet or SSH through the WAN, LAN or LAN/WAN. Only the Administrator is allowed to use Telnet and SSH for remote management. | |
Cancel | Click Cancel to restore your previously saved settings. | |
OK | Click OK to save your changes. | |
