Time Settings
Time Settings Overview
This chapter shows you how to configure system related settings, such as system date and time.
Time
For effective scheduling and logging, the Zyxel Device system time must be accurate. Use this screen to configure the Zyxel Device’s time based on your local time zone. You can enter a time server address, select the time zone where the Zyxel Device is physically located, and configure Daylight Savings settings if needed.
To change your Zyxel Device’s time and date, click Maintenance > Time. The screen appears as shown.
Maintenance > Time
The following table describes the fields in this screen.
Maintenance > Time
LABEL
Description
Current Date/Time
Current Time
This displays the time of your Zyxel Device.
Each time you reload this screen, the Zyxel Device synchronizes the time with the time server.
Current Date
This displays the date of your Zyxel Device.
Each time you reload this screen, the Zyxel Device synchronizes the date with the time server.
Time and Date Setup
Time Protocol
This displays the time protocol used by your Zyxel Device.
First – Fifth Time Server Address
Select an NTP time server from the drop-down list box for the first to fifth time servers.
Otherwise, select Other and enter the IP address or URL (up to 29 printable characters in length) of your time server.
Select None if you do not want to configure the time server.
Check with your ISP/network administrator if you are unsure of this information.
The Zyxel Device uses the time servers as shown in the web configurator by default.
Time Zone
Time zone
Choose the time zone of your location. This will set the time difference between your time zone and Greenwich Mean Time (GMT).
Detect Time Zone
Click this switch to enable or disable automatic time zone detection on your Zyxel Device. Enable this switch if you are not sure of your time zone or if your time zone is not in the drop-down list.
Daylight Savings
Daylight Saving Time is a period from late spring to early fall when many countries set their clocks ahead of normal local time by one hour to give more daytime light in the evening.
Active
Click this switch to enable or disable Daylight Saving Time. When the switch turns blue, the function is enabled. Otherwise, it is not.
Start Rule
Configure the day and time when Daylight Saving Time starts if you enabled Daylight Saving. You can select a specific date in a particular month or a specific day of a specific week in a particular month. The Time field uses the 24 hour format. Here are a couple of examples:
Daylight Saving Time starts in most parts of the United States on the second Sunday of March. Each time zone in the United States starts using Daylight Saving Time at 2 A.M. local time. So in the United States, set the day to Second, Sunday, the month to March and the time to 2 in the Hour field.
Daylight Saving Time starts in the European Union on the last Sunday of March. All of the time zones in the European Union start using Daylight Saving Time at the same moment (1 A.M. GMT or UTC). So in the European Union you would set the day to Last, Sunday and the month to March. The time you select in the o'clock field depends on your time zone. In Germany for instance, you would select 2 in the Hour field because Germany's time zone is one hour ahead of GMT or UTC (GMT+1).
For example, if you are in the United States and Daylight Saving Time starts on March 28th, the Zyxel Device time of 6 a.m will become 7 a.m.
End Rule
Configure the day and time when Daylight Saving Time ends if you enabled Daylight Saving. You can select a specific date in a particular month or a specific day of a specific week in a particular month. The Time field uses the 24 hour format. Here are a couple of examples:
Daylight Saving Time ends in the United States on the first Sunday of November. Each time zone in the United States stops using Daylight Saving Time at 2 A.M. local time. So in the United States you would set the day to First, Sunday, the month to November and the time to 2 in the Hour field.
Daylight Saving Time ends in the European Union on the last Sunday of October. All of the time zones in the European Union stop using Daylight Saving Time at the same moment (1 A.M. GMT or UTC). So in the European Union you would set the day to Last, Sunday, and the month to October. The time you select in the o'clock field depends on your time zone. In Germany for instance, you would select 2 in the Hour field because Germany's time zone is one hour ahead of GMT or UTC (GMT+1).
For example, if you are in the United States and Daylight Saving Time ends on October 31, the Zyxel Device time of 6 a.m will become 5 a.m.
Cancel
Click Cancel to exit this screen without saving.
Apply
Click Apply to save your changes.
