Label | Description |
Service Control | |
WAN Interface used for services | Select Any_WAN to have the Zyxel Device automatically activate the remote management service when any WAN connection is up. Select Multi_WAN and then select one or more WAN connections to have the Zyxel Device activate the remote management service when the selected WAN connections are up. |
WWAN | Enable the WWAN (cellular) connection configured in Network Setting > Broadband > Cellular Backup to access the service on the Zyxel Device. |
ETHWAN | Enable the Ethernet WAN connection configured in Network Setting > Broadband > Ethernet WAN to access the service on the Zyxel Device. |
ADSL | Enable the ADSL connection configured in Network Setting > Broadband > Add New WAN Interface or Modify to access the service on the Zyxel Device. |
VDSL | Enable the VDSL WAN connection configured in Network Setting > Broadband > Add New WAN Interface or Modify to access the service on the Zyxel Device. |
GPON | Enable the Gigabit Ethernet Passive Optical Network WAN connection configured in Network Setting > Broadband > Add New WAN Interface or Modify to access the service on the Zyxel Device. |
Service | This is the service you may use to access the Zyxel Device. |
LAN | Select the Enable checkbox for the corresponding services that you want to allow access to the Zyxel Device from the LAN. |
WLAN | Select the Enable checkbox for the corresponding services that you want to allow access to the Zyxel Device from the WLAN. |
WAN | Select the Enable checkbox for the corresponding services that you want to allow access to the Zyxel Device from all WAN connections. |
Trust Domain | Select the Enable checkbox for the corresponding services that you want to allow access to the Zyxel Device from the trusted host IP address. |
Port | You may change the server port number for a service if needed, however you must use the same port number in order to use that service for remote management. |
Redirect | To allow only secure Web Configurator access, select this to redirect all HTTP connection requests to the HTTPS server. For example, if you enter http://192.168.1.1 in your browser to access the Web Configurator, then the Zyxel Device will automatically change this to the more secure https://192.168.1.1 for access. |
Apply | Click Apply to save your changes back to the Zyxel Device. |
Cancel | Click Cancel to restore your previously saved settings. |
Add Trust Domain | Click this to add a trusted host IP address. |
IP Address | This field shows a trusted host IP address. |
Delete | Click the Delete icon to remove the trusted host IP address. |
label | description |
IP Address | Enter a public IPv4/IPv6 IP address which is allowed to access the service on the Zyxel Device from the WAN. |
OK | Click OK to save your changes back to the Zyxel Device. |
