LABEL | Description |
Syslog Settings | |
Syslog Logging | Slide the switch to the right to enable syslog logging. |
Mode | Select Remote to have the Zyxel Device send to an external syslog server. Select Local File to have the Zyxel Device save the log file on the Zyxel Device itself. Select Local File and Remote to have the Zyxel Device save the log file on the Zyxel Device itself and send it to an external syslog server. |
Syslog Server | Enter the server name or IP address of the syslog server that will log the selected categories of logs. |
UDP Port | Enter the port number used by the syslog server. |
Enable Syslog over TLS | Use Syslog over TLS to securely send logs from the Zyxel Device to the syslog server using TLS encryption. On the Zyxel Device, first generate a certificate for syslog authentication of the Zyxel Device. The CN (Certificate Name) must match the IP address of the Zyxel Device's interface to the syslog server. Go to Certificates > Local CA and import a certificate for syslog authentication. This is required. |
Local Certificate Used by Syslog Client | Optionally, the Syslog server may also request a certificate from the Zyxel Device for mutual authentication. Go to Certificates > Local Certificate and import a Zyxel Device certificate that the syslog server can use to verify the Zyxel Device. |
E-mail Log Settings | |
E-mail Log Settings | Slide the switch to the right to allow to the email address specified in Send Log to. |
Mail Account | Select a server specified in Maintenance > E-mail Notifications to send the logs to. |
System Log Mail Subject | This field allows you to enter a descriptive name for the system log email (for example Zyxel System Log). Up to 127 printable characters are allowed for the System Log Mail Subject including special characters inside the square brackets [!#%()*+,–./:=?@[]\{}~]. |
Security Log Mail Subject | This field allows you to enter a descriptive name for the security log email (for example Zyxel Security Log). Up to 127 printable characters are allowed for the Security Log Mail Subject including special characters inside the square brackets [!#%()*+,–./:=?@[]\{}~]. |
Send Log to | This field allows you to enter the log’s designated email recipient. The log’s format is plain text file sent as an email attachment. |
Send Alarm to | This field allows you to enter the alarm’s designated e-mail recipient. The alarm’s format is plain text file sent as an email attachment. |
Alarm Interval | Select the frequency of showing of the alarm. |
Active Log | |
System Log | Select the categories of System Logs that you want to record. |
Security Log | Select the categories of Security Logs that you want to record. |
Apply | Click Apply to save your changes. |
Cancel | Click Cancel to restore your previously saved settings. |
