Legal Information
Copyright
Copyright © 2025 by Zyxel and/or its affiliates.
The contents of this publication may not be reproduced in any part or as a whole, transcribed, stored in a retrieval system, translated into any language, or transmitted in any form or by any means, electronic, mechanical, magnetic, optical, chemical, photocopying, manual, or otherwise, without the prior written permission of Zyxel and/or its affiliates.
Published by Zyxel and/or its affiliates. All rights reserved.
Disclaimer
Zyxel does not assume any liability arising out of the application or use of any products, or software described herein. Neither does it convey any license under its patent rights nor the patent rights of others. Zyxel further reserves the right to make changes in any products described herein without notice. This publication is subject to change without notice.
Regulatory Notice and Statement
United States of America
The following information applies if you use the product within USA area.
FCC Statement
• The device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions:
(1) This device may not cause harmful interference, and
(2) This device must accept any interference received, including interference that may cause undesired operation.
• Changes or modifications not expressly approved by the party responsible for compliance could void the user’s authority to operate the equipment.
NOTE: This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to Part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses, and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures:
• Reorient or relocate the receiving antenna
• Increase the separation between the equipment and receiver
• Connect the equipment into an outlet on a circuit different from that to which the receiver is connected
• Consult the dealer or an experienced radio/TV technician for help
FCC Radiation Exposure Statement
• This device complies with FCC Radio Frequency (RF) radiation exposure limits set forth for an uncontrolled environment.
• This transmitter must be at least 20 cm from the user and must not be co-located or operating in conjunction with any other antenna or transmitter.
The following information applies for products operating in the 5.925 - 7.125 GHz band.
Low-power Indoor Access Point
• FCC regulations restrict the operation of this device to indoor use only.
• The operation of this device is prohibited on oil platforms, cars, trains, boats, and aircraft, except that operation of this device is permitted in large aircraft while flying above 10,000 feet in the 5.925 - 6.425 GHz band.
• Operation of transmitters in the 5.925 - 7.125 GHz band is prohibited for control of or communications with unmanned aircraft systems.
Standard Power Access Point
• The operation of this device is prohibited on oil platforms, cars, trains, boats, and aircraft.
Industry Canada radiation exposure statement
This equipment complies with ISED radiation exposure limits set forth for an uncontrolled environment. This equipment should be installed and operated with a minimum distance of 20 cm between the radiator and your body.
Déclaration d'exposition aux radiations
Cet équipement est conforme aux limites d'exposition aux rayonnements ISED établies pour un environnement non contrôlé. Cet équipement doit être installé et utilisé avec un minimum de 20 cm de distance entre la source de rayonnement et votre corps.
Europe and the United Kingdom
The following information applies if you use the product within the European Union and United Kingdom.
Declaration of Conformity with Regard to EU Directive 2014/53/EU (Radio Equipment Directive, RED) and UK Radio Equipment Regulations 2017
Model List: DX3300-T0, DX3300-T1, DX3301-T0, DX5401-B0, DX5401-B1, EX3300-T0, EX3300-T1, EX3301-T0, EX3500-T0, EX3501-T0, EX3600-T0, EX5401-B0, EX5401-B1, EX5600-T1, EX5601-T0, EX5601-T1, EX7501-B0, PX3321-T1, PX3321-T3, PX5301-T0, PX5302-00 AM7510-00,
• Compliance information for wireless products relevant to the EU, United Kingdom, and other Countries following the EU Directive 2014/53/EU (RED) and UK Radio Equipment Regulations 2017. And this product may be used in all EU countries (and other countries following the EU Directive 2014/53/EU) and United Kingdom without any limitation except for the countries mentioned below table:
• In the majority of the EU, United Kingdom, and other European countries, the 5 GHz bands have been made available for the use of wireless local area networks (LANs). Later in this document you will find an overview of countries in which additional restrictions or requirements or both are applicable. The requirements for any country may evolve. Zyxel recommends that you check with the local authorities for the latest status of their national regulations for the 5 GHz wireless LANs.
• If this device operates in the 5150 to 5350 MHz band, it is for indoor use only.
• This equipment should be installed and operated with a minimum distance of 20cm between the radio equipment and your body.
• The maximum RF operating power for each band is as follows:
• DX3300-T0 / DX3301-T0 / EX3300-T0 / EX3301-T0
• 95.28 mW for the 2,400 to 2,483.5 MHz band
• 192.31 mW for the 5,150 to 5,350 MHz band
• 912.01 mW for the 5,470 to 5,725 MHz band
• DX5401-B0 / EX5401-B0
• 8.57 mW for the 2,400 to 2,483.5 MHz band (Zigbee)
• 97.72 mW for the 2,400 to 2,483.5 MHz band (Wi-Fi)
• 177.42 mW for the 5,150 to 5,350 MHz band
• 857.04 mW for the 5,470 to 5,725 MHz band
• DX5401-B1 / EX5401-B1
• 96.61 mW for the 2,400 to 2,483.5 MHz band
• 193.64 mW for the 5,150 to 5,350 MHz band
• 698.23 mW for the 5,470 to 5,725 MHz band
• EX3500-T0 / EX3501-T0
• 191.43 mW for the 5,150 to 5,350 MHz band
• 916.22 mW for the 5,470 to 5,725 MHz band
• EX3600-T0
• 90.99 dBm for the 2,400 to 2,483.5 MHz band
• 192.75 dBm for the 5,150 to 5,350 MHz band
• 602.55 dBm for the 5,470 to 5,725 MHz band
• 182.81 dBm for the 5,725 to 5,850 MHz band (UK only)
• EX5600-T1 / EX5601-T0 / EX5601-T1
• 86.5 mW for the 2,400 to 2,483.5 MHz band
• 176.6 mW for the 5,150 to 5,350 MHz band
• 870.1 mW for the 5,470 to 5,725 MHz band
• 170.61 mW for the 5,725 to 5,850 MHz band (UK only)
• EX7501-B0
• 88.51 mW for the 2,400 to 2,483.5 MHz band
• 179.47 mW for the 5,150 to 5,350 MHz band
• 883.08 mW for the 5,470 to 5,725 MHz band
• 177.42 mW for the 5.725 to 5.850 MHz band (UK only)
• DX3300-T1 / EX3300-T1
• 97.5 mW for the 2,400 to 2,483.5 MHz band
• 194.09 mW for the 5,150 to 5,350 MHz band
• 922.57 mW for the 5,470 to 5,725 MHz band
• PX3321-T1
• 99.31 mW for the 2,400 to 2,483.5 MHz band
• 194.98 mW for the 5,150 to 5,350 MHz band
• 997.7 mW for the 5,470 to 5,725 MHz band
• PX3321-T3
• 100 mW for the 2,400 to 2,483.5 MHz band
• 199.53 mW for the 5,150 to 5,350 MHz band
• 1000 mW for the 5,470 to 5,725 MHz band
• PX5301-T0
• 92.26 mW for the 2,400 to 2,483.5 MHz band
• 185.35 mW for the 5,150 to 5,350 MHz band
• 957.19 mW for the 5,470 to 5,725 MHz band
• PX5302-00
• 90.36 mW for the 2,400 to 2,483.5 MHz band
• 173.78 mW for the 5,150 to 5,350 MHz band
• 788.86 mW for the 5,470 to 5,725 MHz band
Notes:
• Not all European states that implement EU Directive 2014/53/EU are European Union (EU) members.
• The regulatory limits for maximum output power are specified in EIRP. The EIRP level (in dBm) of a device can be calculated by adding the gain of the antenna used (specified in dBi) to the output power available at the connector (specified in dBm).
List of national codes
Country | ISO 3166 2 letter code | Country | ISO 3166 2 letter code |
Austria | AT | Liechtenstein | LI |
Belgium | BE | Lithuania | LT |
Bulgaria | BG | Luxembourg | LU |
Croatia | HR | Malta | MT |
Cyprus | CY | Netherlands | NL |
Czech Republic | CZ | Norway | NO |
Denmark | DK | Poland | PL |
Estonia | EE | Portugal | PT |
Finland | FI | Romania | RO |
France | FR | Serbia | RS |
Germany | DE | Slovakia | SK |
Greece | GR | Slovenia | SI |
Hungary | HU | Spain | ES |
Iceland | IS | Switzerland | CH |
Ireland | IE | Sweden | SE |
Italy | IT | Turkey | TR |
Latvia | LV | United Kingdom | GB |
Safety Warnings
• To avoid possible eye injury, do NOT look into an operating fiber-optic module’s connector.
• Do not put the device in a place that is humid, dusty, has extreme temperatures, or that blocks the device ventilation slots. These conditions may harm your device.
• Please refer to the device back label, datasheet, box specifications or catalog information for power rating of the device and operating temperature.
• There is a remote risk of electric shock from lightning: (1) Do not use the device outside, and make sure all the connections are indoors. (2) Do not install or service this device during a thunderstorm.
• The Power Supply is not waterproof, avoid contact with liquid. Handle the Power Supply with care; do not pry open, nor pull or press the pins on it.
• Do not expose your device to dampness, dust or corrosive liquids.
• Do not store things on the device.
• Do not obstruct the device ventilation slots as insufficient airflow may harm your device. For example, do not place the device in an enclosed space such as a box or on a very soft surface such as a bed or sofa.
• Do not install or service this device during a thunderstorm. There is a remote risk of electric shock from lightning.
• Connect ONLY suitable accessories to the device.
• Do not open the device. Opening or removing the device covers can expose you to dangerous high voltage points or other risks.
• Only qualified service personnel should service or disassemble this device. Please contact your vendor for further information.
• Make sure to connect the cables to the correct ports.
• Place connected cables carefully so that no one will step on them or stumble over them.
• Disconnect all cables from this device before servicing or disassembling.
• Do not remove the plug and connect it to a power outlet by itself; always attach the plug to the power adaptor first before connecting it to a power outlet.
• Do not allow anything to rest on the power adaptor or cord and do NOT place the product where anyone can walk on the power adaptor or cord.
• Please use the provided or designated connection cables/power cables/adaptors. Connect the power adaptor or cord to the right supply voltage (for example, 120 VAC in North America or 230 VAC in Europe). If the power adaptor or cord is damaged, it might cause electrocution. Remove the damaged power adaptor or cord from the device and the power source. Contact your local vendor to order a new one.
• CAUTION: There is a risk of explosion if you replace the device battery with an incorrect one. Dispose of used batteries according to the instructions. Dispose them at the applicable collection point for the recycling of electrical and electronic devices. For detailed information about recycling of this product, please contact your local city office, your household waste disposal service or the store where you purchased the product.
• Do not leave a battery in an extremely high temperature environment or surroundings since it can result in an explosion or the leakage of flammable liquid or gas.
• Do not subject a battery to extremely low air pressure since it may result in an explosion or the leakage of flammable liquid or gas.
• The following warning statements apply, where the disconnect device is not incorporated in the device or where the plug on the power supply cord is intended to serve as the disconnect device,
– For a permanently connected device, a readily accessible method to disconnect the device shall be incorporated externally to the device;
– For a pluggable device, the socket-outlet shall be installed near the device and shall be easily accessible.
• This product is intended to be supplied by a DC power source marked 'L.P.S' or `Limited Power Source'. The rating for each model is as follows:
• DX3300-T0 / DX3301-T0 / EX3300-T0 / EX3301-T0: 12 VDC / 1.5 A or 2 A / Tma 40 °C
• DX3300-T1 / EX3300-T1 / EX3500-T0 / EX3501-T0 / PX3321-T1 / PX3321-T3 / PX5301-T0 / PX5302-00: 12 VDC / 1.5A / Tma 40 °C
• DX5401-B0 / EX5401-B0 / DX5401-B1 / EX5401-B1 / EX5600-T1 / EX5601-T0 / EX5601-T1: 12 VDC / 3A / Tma 40 °C
• EX3600-T0: 12 VDC / 2A / Tma 40 °C
• 12 VDC / 1 A / Tma 40 °CEX7501-B0: 12 VDC / 3.5 A / Tma 40 °C
The following information applies for products with PON/Laser:
• CLASS 1 LASER PRODUCT & “IEC 60825-1:2014”
• CLASS 1 CONSUMER LASER PRODUCT & "EN 50689:2021"
• Caution – Use of controls or adjustments or performance of procedures other than those specified herein may result in hazardous radiation exposure.
• Complies with 21 CFR 1040.10 and 1040.11 except for conformance with IEC 60825-1 Ed. 3., as described in Laser Notice No. 56, dated May 8, 2019.
Important Safety Instructions
• Caution! The RJ-45 jacks are not used for telephone line connection.
• Caution! Do not use this product near water, for example a wet basement or near a swimming pool.
• Caution! Avoid using this product (other than a cordless type) during an electrical storm. There may be a remote risk of electric shock from lightning.
• Caution! Always disconnect all telephone lines from the wall outlet before servicing or disassembling this product.
• Attention: Les prises RJ-45 ne sont pas utilisés pour la connexion de la ligne téléphonique.
• Attention: Ne pas utiliser ce produit près de l'eau, par exemple un sous-sol humide ou près d'une piscine.
• Attention: Évitez d'utiliser ce produit (autre qu'un type sans fil) pendant un orage. Il peut y avoir un risque de choc électrique de la foudre.
• Attention: Toujours débrancher toutes les lignes téléphoniques de la prise murale avant de réparer ou de démonter ce produit.
• Attention: L'utilisation des commandes ou reglages ou l'execution des procedures autres que celles specifiees dans les presents exigences peuvent etre la cause d'une exposition a un rayonnement dangereux
Environment Statement
ErP (Energy-related Products)
Zyxel products put on the EU and United Kingdom market in compliance with the requirement of the European Parliament and the Council published Directive 2009/125/EC and UK regulation establishing a framework for the setting of ecodesign requirements for energy-related products (recast), so called as "ErP Directive (Energy-related Products directive) as well as ecodesign requirement laid down in applicable implementing measures, power consumption has satisfied regulation requirements which are:
• Network standby power consumption < 8 W, and/or
• Off mode power consumption < 0.5 W, and/or
• Standby mode power consumption < 0.5 W.
(Wireless setting, please refer to the chapter about wireless settings for more detail.)
Disposal and Recycling Information
The symbol below means that according to local regulations your product and/or its battery shall be disposed of separately from domestic waste. If this product is end of life, take it to a recycling station designated by local authorities. At the time of disposal, the separate collection of your product and/or its battery will help save natural resources and ensure that the environment is sustainable development.
Die folgende Symbol bedeutet, dass Ihr Produkt und/oder seine Batterie gemäß den örtlichen Bestimmungen getrennt vom Hausmüll entsorgt werden muss. Wenden Sie sich an eine Recyclingstation, wenn dieses Produkt das Ende seiner Lebensdauer erreicht hat. Zum Zeitpunkt der Entsorgung wird die getrennte Sammlung von Produkt und/oder seiner Batterie dazu beitragen, natürliche Ressourcen zu sparen und die Umwelt und die menschliche Gesundheit zu schützen.
El símbolo de abajo indica que según las regulaciones locales, su producto y/o su batería deberán depositarse como basura separada de la doméstica. Cuando este producto alcance el final de su vida útil, llévelo a un punto limpio. Cuando llegue el momento de desechar el producto, la recogida por separado éste y/o su batería ayudará a salvar los recursos naturales y a proteger la salud humana y medioambiental.
Le symbole ci-dessous signifie que selon les réglementations locales votre produit et/ou sa batterie doivent être éliminés séparément des ordures ménagères. Lorsque ce produit atteint sa fin de vie, amenez-le à un centre de recyclage. Au moment de la mise au rebut, la collecte séparée de votre produit et/ou de sa batterie aidera à économiser les ressources naturelles et protéger l'environnement et la santé humaine.
Il simbolo sotto significa che secondo i regolamenti locali il vostro prodotto e/o batteria deve essere smaltito separatamente dai rifiuti domestici. Quando questo prodotto raggiunge la fine della vita di servizio portarlo a una stazione di riciclaggio. Al momento dello smaltimento, la raccolta separata del vostro prodotto e/o della sua batteria aiuta a risparmiare risorse naturali e a proteggere l'ambiente e la salute umana.
Symbolen innebär att enligt lokal lagstiftning ska produkten och/eller dess batteri kastas separat från hushållsavfallet. När den här produkten når slutet av sin livslängd ska du ta den till en återvinningsstation. Vid tiden för kasseringen bidrar du till en bättre miljö och mänsklig hälsa genom att göra dig av med den på ett återvinningsställe.
台灣
以下訊息僅適用於產品具有無線功能且銷售至台灣地區
• 取得審驗證明之低功率射頻器材,非經核准,公司、商號或使用者均不得擅自變更頻率、加大功率或變更原設計之特性及功能。
• 低功率射頻器材之使用不得影響飛航安全及干擾合法通信;經發現有干擾現象時,應立即停用,並改善至無干擾時方得繼續使用。前述合法通信,指依電信管理法規定作業之無線電通信。低功率射頻器材須忍受合法通信或工業、科學及醫療用電波輻射性電機設備之干擾。
• 本機限在不干擾合法電台與不被干擾保障條件下於室內使用。本產品使用時建議應距離人體 20 cm 以上。
• 無線資訊傳輸設備忍受合法通信之干擾且不得干擾合法通信;如造成干擾,應立即停用, 俟無干擾之虞,始得繼續使用。
• 無線資訊傳輸設備的製造廠商應確保頻率穩定性,如依製造廠商使用手冊上所述正常操作, 發射的信號應維持於操作頻帶中
• 使用無線產品時,應避免影響附近雷達系統之操作。
• 高增益指向性天線只得應用於固定式點對點系統。
以下訊息僅適用於產品屬於專業安裝並銷售至台灣地區
• 本器材須經專業工程人員安裝及設定,始得設置使用,且不得直接販售給一般消費者。
安全警告 – 為了您的安全,請先閱讀以下警告及指示:
• 請勿將此產品接近水、火焰或放置在高溫的環境。
• 避免設備接觸:
– 任何液體 - 切勿讓設備接觸水、雨水、高濕度、污水腐蝕性的液體或其他水份。
– 灰塵及污物 - 切勿接觸灰塵、污物、沙土、食物或其他不合適的材料。
• 雷雨天氣時,不要安裝或維修此設備。有遭受電擊的風險。
• 切勿重摔或撞擊設備,並勿使用不正確的電源變壓器。
• 若接上不正確的電源變壓器會有爆炸的風險。
• 請勿隨意更換產品內的電池。
• 如果更換不正確之電池型式,會有爆炸的風險,請依製造商說明書處理使用過之電池。
• 請將廢電池丟棄在適當的電器或電子設備回收處。
• 請勿將設備解體。
• 請勿阻礙設備的散熱孔,空氣對流不足將會造成設備損害。
• 請使用隨貨提供或指定的連接線/電源線/電源變壓器,將其連接到合適的供應電壓(如:台灣供應電壓110伏特)。
• 假若電源變壓器或電源變壓器的纜線損壞,請從插座拔除,若您還繼續插電使用,會有觸電死亡的風險。
• 請勿試圖修理電源變壓器或電源變壓器的纜線,若有毀損,請直接聯絡您購買的店家,購買一個新的電源變壓器。
• 請勿將此設備安裝於室外,此設備僅適合放置於室內。
• 請勿隨一般垃圾丟棄。
• 請參閱產品背貼上的設備額定功率。
• 請參考產品型錄或是彩盒上的作業溫度。
• 產品沒有斷電裝置或者採用電源線的插頭視為斷電裝置的一部分,以下警語將適用:
– 對永久連接之設備, 在設備外部須安裝可觸及之斷電裝置;
– 對插接式之設備, 插座必須接近安裝之地點而且是易於觸及的。
About the Symbols
Various symbols are used in this product to ensure correct usage, to prevent danger to the user and others, and to prevent property damage. The meaning of these symbols are described below. It is important that you read these descriptions thoroughly and fully understand the contents.
Explanation of the Symbols
Symbol | Explanation |
| Alternating current (AC): AC is an electric current in which the flow of electric charge periodically reverses direction. |
| Direct current (DC): DC is the unidirectional flow or movement of electric charge carriers. |
| Earth; ground: A wiring terminal intended for connection of a Functional Earthing Conductor. |
| Class II equipment: The method of protection against electric shock in the case of class II equipment is either double insulation or reinforced insulation. |
Viewing Certifications
Go to
http://www.zyxel.com to view this product’s documentation and certifications.
Zyxel Limited Warranty
Zyxel warrants to the original end user (purchaser) that this product is free from any defects in material or workmanship for a specific period (the Warranty Period) from the date of purchase. The Warranty Period varies by region. Check with your vendor and/or the authorized Zyxel local distributor for details about the Warranty Period of this product. During the warranty period, and upon proof of purchase, should the product have indications of failure due to faulty workmanship and/or materials, Zyxel will, at its discretion, repair or replace the defective products or components without charge for either parts or labor, and to whatever extent it shall deem necessary to restore the product or components to proper operating condition. Any replacement will consist of a new or re-manufactured functionally equivalent product of equal or higher value, and will be solely at the discretion of Zyxel. This warranty shall not apply if the product has been modified, misused, tampered with, damaged by an act of God, or subjected to abnormal working conditions.
Note
Repair or replacement, as provided under this warranty, is the exclusive remedy of the purchaser. This warranty is in lieu of all other warranties, express or implied, including any implied warranty of merchantability or fitness for a particular use or purpose. Zyxel shall in no event be held liable for indirect or consequential damages of any kind to the purchaser.
To obtain the services of this warranty, contact your vendor.
Open Source Licenses
This product may contain in part some free software distributed under GPL license terms and/or GPL-like licenses.
To request the source code covered under these licenses, please go to:
https://service-provider.zyxel.com/global/en/gpl-oss-software-notice.
