WiFi Problems
I cannot connect to the Zyxel Device WiFi.
1 Check the WiFi LED status to make sure the Zyxel Device WiFi is on.
2 Make sure your WiFi client is within transmission range of the Zyxel Device.
3 Make sure you entered the correct SSID and password. See the Zyxel Device back label for the default SSID and password.
4 Make sure your WiFi client is using the same WiFi security type (WPA2-PSK, WPA3-SAE, or none) as the Zyxel Device.
5 Make sure the WiFi adapter on your WiFi client is working properly. Right-click your computer's network adapter then select Properties to check your network adapter status.
6 Make sure the WiFi adapter on your WiFi client is IEEE 802.11-compatible and supports the same WiFi standard as the Zyxel Device radio.
The WiFi connection is slow and intermittent.
The following factors may cause interference:
Obstacles: walls, ceilings, furniture, and so on.
Building Materials: metal doors, aluminum studs.
Electrical devices: microwaves, monitors, electric motors, cordless phones, and other wireless devices.
To optimize the speed and quality of your WiFi connection, you can:
Move your wireless device closer to the AP if the signal strength is low.
Reduce wireless interference that may be caused by other WiFi networks or surrounding wireless electronics such as cordless phones.
Place the AP where there are minimum obstacles (such as walls and ceilings) between the AP and the WiFi client.
Reduce the number of WiFi clients connecting to the same AP simultaneously, or add additional APs if necessary.
Try closing some programs that use the Internet, especially peer-to-peer applications. If the WiFi client is sending or receiving a lot of information, it may have too many programs open that use the Internet.
Place the Zyxel Device where there are minimum obstacles (such as walls and ceilings) between the Zyxel Device and the WiFi client. Avoid placing the Zyxel Device inside any type of box that might block WiFi signals.
