UPnP Problems
My computer cannot detect UPnP settings from the Zyxel Device.
1 Make sure that UPnP is enabled in your computer.
2 On the Zyxel Device, make sure that UPnP is enabled on the Network Settings > Home Networking > UPnP screen.
3 Disconnect the Ethernet cable from the Zyxel Device’s Ethernet port or from your computer.
4 Reconnect the Ethernet cable.
5 Restart your computer.
