Firmware Upgrade
Firmware Upgrade
This screen lets you upload new firmware to your Zyxel Device.
Get the latest firmware from your service provider. Then upload the firmware file to your Zyxel Device. The upload process uses HTTP (Hypertext Transfer Protocol). The upload may take up to 3 minutes. After a successful upload, the Zyxel Device will reboot.
Click Maintenance > Firmware Upgrade to open the following screen.
Do NOT turn off the Zyxel Device while firmware upload is in progress!
LABEL
DESCRIPTION
Upgrade Firmware
Restore Default Settings After Firmware Upgrade
Select this to reset all your configurations, including Mesh WiFi settings, to the factory defaults after firmware upgrade. Otherwise, make sure this is cleared if you do not want the Zyxel Device to lose all its current configurations and return to the factory defaults.
*Make sure to back up the Zyxel Device’s configuration settings first in case the reset all settings process is not successful.
Reset All Settings Except Mesh After Firmware Upgrade
Select this to reset all your configurations, except for Mesh WiFi settings, to the factory defaults after firmware upgrade. This minimizes interruption to your Mesh WiFi network after upgrading firmware.
Mesh WiFi settings include:
Controller/Agent Mode
Mesh Internet Access
Main and Guest SSIDs including Guest WiFi isolation
2.4GHz & 5GHz Radios
802.11 Mode
Protected Management Frames
Encryption and WPA keys
Current Firmware Version
This is the current firmware version.
File Path
Enter the location of the file you want to upload in this field or click Choose File/Browse to find it.
Choose File/Browse
Click this to find the .bin file you want to upload. Remember that you must decompress compressed (.zip) files before you can upload them.
Upload
Click this to begin the upload process. This process may take up to 3 minutes.
*Only use firmware for your Zyxel Device’s specific model. Refer to the label on the bottom of your Zyxel Device. For example, if the Zyxel Device’s current firmware version is V5.70(ACDZ.0)B4, you must upload the firmware file containing "ACDZ".
Upgrade WWAN Package
Current WWAN Package Version
This is the current version or the WWAN (Wireless Wide Area Network) package installed in the Zyxel Device. A WWAN package adds support for more 4G USB dongles without you having to upgrade the Zyxel Device’s firmware.
File Path
Choose File/Browse
Upload
After you see the firmware updating screen, wait a few minutes before logging into the Zyxel Device again.
Firmware Uploading
The Zyxel Device automatically restarts in this time causing a temporary network disconnect. In some operating systems, you may see the following icon on your desktop.
Network Temporarily Disconnected
After 2 minutes, log in again and check your new firmware version in the Connection Status screen.
If the upload was not successful, an error screen will appear. Click OK to go back to the Firmware Upgrade screen.
Error Message
