LAN Status
Click System Monitor > Traffic Status > LAN to open the following screen. This screen allows you to view packet statistics for each LAN or WLAN interface on the Zyxel Device.
The following table describes the fields in this screen.
LABEL
Description
Refresh Interval
Select how often you want the Zyxel Device to update this screen.
Interface
This shows the LAN or WLAN interface.
Bytes Sent
This indicates the number of bytes transmitted on this interface.
Bytes Received
This indicates the number of bytes received on this interface.
Interface
This shows the LAN or WLAN interfaces.
Sent (Packets)
Data
This indicates the number of transmitted packets on this interface.
Error
This indicates the number of frames with errors transmitted on this interface.
Drop
This indicates the number of outgoing packets dropped on this interface.
Received (Packets)
Data
This indicates the number of received packets on this interface.
Error
This indicates the number of frames with errors received on this interface.
Drop
This indicates the number of received packets dropped on this interface.
