Policy Route
By default, the Zyxel Device routes packets based on the shortest path to the destination address. Policy routes allow you to override the default behavior and route packets based on other criteria, such as the source address. For example, you can use policy-based routing to direct traffic from specific users through specific connections or distribute traffic across multiple paths for load sharing. Policy-based routing is applied to outgoing packets before the default routing rules are applied.
The Policy Route screen let you view and configure routing policies on the Zyxel Device. Click Network Setting > Routing > Policy Route to open the following screen.
Label
Description
Add New Policy Route
Click this to create a new policy forwarding rule.
This is the index number of the entry.
Status
This field displays whether the DNS route is active or not. A yellow bulb signifies that this DNS route is active. A gray bulb signifies that this DNS route is not active.
Name
This is the name of the rule.
Source IP
This is the source IP address.
Source Subnet Mask
This is the source subnet mask address.
Protocol
This is the transport layer protocol.
Source Port
This is the source port number.
Source MAC
This is the source MAC address.
Source Interface
This is the interface from which the matched traffic is sent.
WAN Interface
This is the WAN interface through which the traffic is routed.
Modify
Click the Edit icon to edit this policy.
Click the Delete icon to remove a policy from the Zyxel Device. A window displays asking you to confirm that you want to delete the policy.
Add or Edit Policy Route
Click Add New Policy Route in the Policy Route screen or click the Edit icon next to a policy. Use this screen to configure the required information for a policy route.
Network Setting > Routing > Policy Route: Add or Edit
Label
Description
Active
Click this switch to activate this policy route. Otherwise, click to disable.
Route Name
Enter a descriptive name of this policy route. You can use up to 15 printable characters except [ " ], [ ` ], [ ' ], [ < ], [ > ], [ ^ ], [ $ ], [ | ], [ & ], or [ ; ]. Spaces are allowed.
Source IP Address
Enter the source IP address.
Source Subnet Mask
Enter the source subnet mask address.
Protocol
Select the transport layer protocol (TCP, UDP, or None).
Source Port
Enter the source port number.
Source MAC
Enter the source MAC address.
Source Interface (example: br0 or LAN1 – LAN4)
Enter the name of the interface from which the matched traffic is sent.
WAN Interface
Select a WAN interface through which the traffic is sent. You must have the WAN interfaces already configured in the Broadband screens.
Cancel
Click Cancel to exit this screen without saving.
OK
Click OK to save your changes.
