QoS Monitor
To view the Zyxel Device’s QoS packet statistics, click Network Setting > QoS > Monitor. The screen appears as shown.
LABEL
Description
Refresh Interval
Select how often you want theZyxel Device to update this screen. Select None to stop refreshing
Interface Monitor
This is the index number of the entry.
Name
This shows the name of the interface on the Zyxel Device.
Pass Rate (bps)
This shows how many packets forwarded to this interface are transmitted successfully.
Drop Rate (bps)
This shows how many packets forwarded to this interface are dropped.
Queue Monitor
Name
This shows the name of the queue.
Pass Rate (bps)
This shows how many packets assigned to this queue are transmitted successfully.
Drop Rate (bps)
This shows how many packets assigned to this queue are dropped.
