TFTP Server Name
Use the TFTP Server Name screen to identify a TFTP server for configuration file download using DHCP option 66. RFC 2132 defines the option 66 open standard. DHCP option 66 supports the IP address or the host name of a single TFTP server.
Click Network Setting > Home Networking > TFTP Server Name to open this screen.
Label
Description
TFTP Server Name
Enter the IP address or the host name of a single TFTP server.
Cancel
Click Cancel to restore your previously saved settings.
Apply
Click Apply to save your changes.
Any Port Any Service (APAS) allows a LAN device to use any available port to access any available service from a remote WAN device. Typically, a LAN device, such as a Set Top Box (STB), would have to use a specific port to access video streams from a video server. With APAS, the video streams only need to be received through the specified Bridge WAN interface for the LAN device specified in the APAS rule. You can connect the LAN device to any LAN port. Other LAN devices can access the Internet using the default gateway.
Unlike Port Forwarding, which forwards traffic based on port numbers, you do not need to know the port number for the video traffic from the IPTV server. You just select the LAN device host name or enter its MAC address and select a Bridge WAN interface.
Use the wildcard '*' for a range of MAC addresses for multiple LAN devices. For example, enter 00:13:49:*:*:* for all LAN devices from a vendor with the MAC OUI 00:13:49. (range). Any device with that MAC OUI aa:bb:cc connected to any LAN port on the Zyxel Device can access services or can be accessed for services through the specified Bridge WAN interface. For example, the LAN device could be an STB receiving video streams from a video server, or it could be a server, allowing access to it through the specified Bridge WAN interface.
*You must configure a Bridge WAN interface in advance.
As APAS allows incoming traffic from any port to access any service on a configured LAN device, it may be difficult to distinguish between appropriate and malicious traffic going to the LAN device. Make sure to properly configure firewall rules to protect the LAN device, and monitor network traffic for suspicious activity.
Click Network Setting > Home Networking > APAS to open this screen.
label
Description
Enable
Click Enable to activate APAS.
Add new MAC Rule
Click this button to add a new MAC rule. You can create up to eight MAC rules.
This is the index number.
Name
This is the name of the rule.
MAC Rule
This is the LAN host MAC address that is applied to the rule.
WAN Interface
This is the bridge WAN interface for incoming traffic.
Cancel
Click Cancel to restore your previously saved changes.
OK
Click OK to save your changes.
Add APAS
Use this screen to create a new MAC rule. Click Network Setting > Home Networking > APAS > Add New MAC Rule to open the following screen.
label
Description
Enable
Click this to enable APAS on the Zyxel Device.
Name
Enter a name of up to 64 characters for the APAS rule to this host(s). Allowed characters for Name include the following within quotes: " !#%()*+,-./0123456789:=?@ABCDEFGHIJKLMNOPQRSTUVWXYZ[\\]_abcdefghijklmnopqrstuvwxyz{}~"
Select Device Info
Select a connected LAN host or select Manual Input to enter the MAC address of a client that is not yet connected and does not display in Connection Status > Connectivity.
MAC Rule
If you selected Manual Input for Select Device Info, then enter the LAN host MAC address here. You can use the wildcard '*' for a MAC address range. For example, enter 00:13:49:*:*:* for all LAN devices from a vendor with the MAC OUI 00:13:49.
Bridge WAN Name
Select a Bridge WAN interface for incoming traffic to apply the rule. You must have created at least one Bridge WAN interface in Network Setting > Broadband screen.
Cancel
Click Cancel to exit this screen without saving.
OK
