User Account
User Account Overview
In the User Account screen, you can view the settings of the “admin” that you use to log into the Zyxel Device to manage it.
User Account
Click Maintenance > User Account to open the following screen. Use this screen to create and manage user accounts and their privileges on the Zyxel Device.
Label
Description
Add New Account
Click this button to add a new user account (up to four Administrator accounts and four User accounts).
This is the index number.
Active
This indicates whether the user account is active or not.
The checkbox is selected when the user account is enabled. It is cleared when it is disabled.
User Name
This displays the name of the account used to log into the Zyxel Device Web Configurator.
Retry Times
This displays the number of times consecutive wrong passwords can be entered for this account. 0 means there is no limit.
Idle Timeout
This displays the length of inactive time before the Zyxel Device will automatically log the user out of the Web Configurator.
Lock Period
This field displays the length of time a user must wait before attempting to log in again after a number of consecutive wrong passwords have been entered as defined in Retry Times.
Group
This field displays this user has Administrator privileges.
Remote Privilege
This field displays whether this user can access the Zyxel Device with HTTP, Telnet or SSH through the WAN, LAN or LAN/WAN.
Modify
Click the Edit icon to configure the entry.
Click the Delete icon to remove the entry.
Cancel
Click Cancel to restore your previously saved settings.
Apply
Click Apply to save your changes.
User Account Add or Edit
Add or change the name of the user account, set the security password and the retry times, and whether this user will have Administrator or User privileges. Click Add New Account or the Edit icon of an existing account in the Maintenance > User Account to open the following screen.
Maintenance > User Account: Add
Maintenance > User Account: Edit
Maintenance > User Account > User Account Add/Edit
Label
Description
Active
Click to enable (switch turns blue) or disable (switch turns gray) to activate or deactivate the user account.
User Name
Enter a name for this account. You can use up to 31 printable characters except [ " ], [ ` ], [ ' ], [ < ], [ > ], [ ^ ], [ $ ], [ | ], [ & ], or [ ; ]. Spaces are allowed.
Password
Enter your new system password. The password must contain at least one numeric and one alphabetic character. You can use 6 – 64 alphanumeric (0-9, a-z, A-Z) and special characters except [ " ], [ ` ], [ ' ], [ < ], [ > ], [ ^ ], [ $ ], [ | ], [ & ], or [ ; ]. Spaces are allowed.
Note that as you type a password, the screen displays a (*) for each character you type. After you change the password, use the new password to access the Zyxel Device.
If you are changing your existing password, you have to first enter your Old Password then enter your New Password.
Verify Password
Enter the new password again for confirmation.
Retry Times
Enter the number of times consecutive wrong passwords can be entered for this account. 0 means there is no limit.
Idle Timeout
Enter the length of inactive time before the Zyxel Device will automatically log the user out of the Web Configurator.
Lock Period
Enter the length of time a user must wait before attempting to log in again after a number of consecutive wrong passwords have been entered as defined in Retry Times.
Group
Specify whether this user will have Administrator or User privileges. An Administrator account can access all Web Configurator menus. A User account can only access Monitor and Maintenance menus.
The maximum account number of Administrator and User are both four. The total number of the users allowed to log in the Zyxel Device at the same time is eight.
The Administrator privileges are the following:
Quick Start setup.
The following screens are visible for setup:
Broadband, Wireless, Home Networking, Routing, NAT, DNS, Firewall, MAC Filter, Voice, Log, Traffic Status, ARP Table, Routing Table, Cellular WAN Status, System, User Account, Remote Management, Time, Email Notification, Log Setting, Firmware Upgrade, Backup/Restore, Reboot, Diagnostic.
The User privileges are the following:
Log, Traffic Status, ARP Table, Routing Table, Cellular WAN Status, User Account, Remote Management, Time, Email Notification, Log Setting, Firmware Upgrade, Backup/Restore, Reboot, Diagnostic.
Remote Privilege
Select whether this user can access the Zyxel Device with HTTP, Telnet or SSH through the WAN, LAN or LAN/WAN. Only the Administrator is allowed to use Telnet and SSH for remote management.
Cancel
OK
Click OK to save your changes.
