Remote Management
MGMT Services
Use this screen to configure the interfaces through which services can access the Zyxel Device. You can also specify service port numbers computers must use to connect to the Zyxel Device. Click Maintenance > Remote Management > MGMT Services to open the following screen.
The following table describes the fields in this screen.
Label
Description
Service Control
WAN Interface used for services
Select Any_WAN to have the Zyxel Device automatically activate the remote management service when any WAN connection is up.
Select Multi_WAN and then select one or more WAN connections to have the Zyxel Device activate the remote management service when the selected WAN connections are up.
WWAN
Enable the WWAN (cellular) connection configured in Network Setting > Broadband > Cellular Backup to access the service on the Zyxel Device.
ETHWAN
Enable the Ethernet WAN connection configured in Network Setting > Broadband > Ethernet WAN to access the service on the Zyxel Device.
ADSL
Enable the ADSL connection configured in Network Setting > Broadband > Add New WAN Interface or Modify to access the service on the Zyxel Device.
VDSL
Enable the VDSL WAN connection configured in Network Setting > Broadband > Add New WAN Interface or Modify to access the service on the Zyxel Device.
GPON
Enable the Gigabit Ethernet Passive Optical Network WAN connection configured in Network Setting > Broadband > Add New WAN Interface or Modify to access the service on the Zyxel Device.
Service
This is the service you may use to access the Zyxel Device.
LAN
Select the Enable checkbox for the corresponding services that you want to allow access to the Zyxel Device from the LAN.
WLAN
Select the Enable checkbox for the corresponding services that you want to allow access to the Zyxel Device from the WLAN.
WAN
Select the Enable checkbox for the corresponding services that you want to allow access to the Zyxel Device from all WAN connections.
Trust Domain
Select the Enable checkbox for the corresponding services that you want to allow access to the Zyxel Device from the trusted host IP address.
Port
You may change the server port number for a service if needed, however you must use the same port number in order to use that service for remote management.
Redirect
To allow only secure Web Configurator access, select this to redirect all HTTP connection requests to the HTTPS server. For example, if you enter http://192.168.1.1 in your browser to access the Web Configurator, then the Zyxel Device will automatically change this to the more secure https://192.168.1.1 for access.
Apply
Cancel
Click Cancel to restore your previously saved settings.
