Diagnostic
Diagnostic
Use this screen to ping, traceroute, nslookup, or speed test for troubleshooting. Ping and traceroute are used to test whether a particular host is reachable. After entering an IP address and clicking one of the buttons to start a test, the results will be shown in the screen. Use nslookup to find the IP address for a host name and vice versa. Use speed test to perform an upload and download throughput test for applications such as file transfer, web browsing and email.
Click Maintenance > Diagnostic to open the following screen.
The following table describes the fields in this screen.
Label
Description
The result of tests is shown here in the info area.
Select Test Method
Ping
Select this to perform a ping test on the IPv4 address or host name in order to test a connection. The ping statistics will show in the info area.
Ping 6
Select this to perform a ping test on the IPv6 address or host name in order to test a connection. The ping statistics will show in the info area.
Trace Route
Select this to perform the IPv4 trace route function. This determines the path a packet takes to the specified host.
Trace Route 6
Select this to perform the IPv6 trace route function. This determines the path a packet takes to the specified host.
Nslookup
Select this to perform a DNS lookup on the IP address or host name.
TCP/IP
Address
Enter the IP address of a computer that you want to perform ping, trace route, nslookup, or speed test in order to test a connection.
Start Test
Click this to perform the selected test method.
